Needing a little help on getting my doors back into shape. The above picture is the passenger side door, do I just shim the back body mounts a little more to get rid of the gap?
Next the drivers side
This door is way outa wack. The middle a lower part of the door sticks out a little past the rear clip. I have know idea on how to get that out. The door is also a little lower at the top. I know this is adjusted by the door hinge bolts, and the same as the passenger door, does raising the rear clip close the gap.
Scott
Reason: spelling
The front gaps are actually OK. Although it's a one piece tilt front end, so I was able to move the front end around enough to match the doors. I may have to redo it once I get the back problem resolved.
