Manifold vacuum tee *** help!!
Old Apr 26, 2010 | 10:52 PM
cherrybombc3's Avatar
cherrybombc3
Default Manifold vacuum tee *** help!!
Well I broke my manifold vacuum tee & need to find another. Anyone know the thread size on an Edelbrock RPM Air Gap manifold. The hole right behind the carb, on top of the runner. I need to find a new tee, any suggestions? I only require the trans vac modulator valve hose & one other port for the headlight doors, etc.
Old Apr 27, 2010 | 05:17 AM
73StreetRace's Avatar
73StreetRace
Could be 3/8" NPT, but not 100% sure.
Old Apr 27, 2010 | 09:26 AM
ctgene's Avatar
ctgene
Banned Scam/Spammer
try Zip Corvette, not sure if these will fit but I believe 3/8 NPT as mentioned is a standard size...
http://www.zip-corvette.com/GroupDetails/SubGroupResults.aspx?gid={a24953e3-6146-4eee-93b1-4044d1966ef6}&SearchType=_GROUP_SEARCH&G roupName=68-78+Intake+Manifold+Vacuum+Fittings&[/URL]
Old Apr 27, 2010 | 09:33 AM
MelWff's Avatar
MelWff
check out Edelbrock part# 8096
http://www.jegs.com/i/Edelbrock/350/...8096+Edelbrock
Old Apr 27, 2010 | 10:02 PM
cherrybombc3
Thanks Guys for the input. Zip nor Wilcox had anything in stock, I even tried different years & configurations. Actually one of them told me I was better off going to a plumbing store. YUK!! My trans modulator valve hard line comes in from the top of the fitting. It is a bit tight with a Holley but it worked. I broke the dang thing I dont think I can straighten out the trans hard line & re-bend it for a side exit fitting & of course nobody has a new different style hard line for sale. I'm in a pickle here. Unless I cut the tight bend off the hard line & make a new bend BUT my original line has a reduced tip, it goes from aprox. 3/16" to aprox. 1/8" where it enters the fitting. Why, I dont know?? Increased pressure??
Old Apr 29, 2010 | 10:45 PM
cherrybombc3
Ok, I managed to find a vacuum fitting from a 68 Vette & bingo, perfect fit & I'm back on the road.
To Manifold vacuum tee *** help!!
