Anyone Not Recommend Using Engine Block Drain Plugs to Flush Coolant?
I would like to flush all my coolant using the two drain plugs on either side of the engine block.
Has anyone ever had a bad experience doing this (broken plug, stripped block, etc.)?
Any reason why I should not use the drain plugs, and simply do a drain & fill?
It's my understanding that when you don't use the engine block drain plugs, then back flush with water, you will be left with ~1 gallon of water in still the block.
My two drain plugs look accessible, I'm just worried that I'll open up a can of worms trying to get them out (or back in, for that matter).
Please correct me if I am wrong.
Water cools better than anti-freeze.
I use about 1 gal. of anti-freeze in my 21? qt. system along with a bottle of water pump lube/corrosion additive.
Car never sees freezing temperatures.
You have to get all the crud that settles in the lower cavities and if it has never been cleaned properly before, there will be a lot.
Each heating and cooling cycle of the engine loosens and puts a certain amount in suspension and disperses it throughout the whole system. Big enough pieces will plug the radiator tubes. Problem is even worse with alum rads since the inside of the tubes are smaller than the brass radiators.
Try some penetrant and with a long flat punch, hit the top of the plug hard a few times. Repeat the process several times and then use the suggested 6 point socket. If all else fails, you can drill out the plug, chase the thread and always install hex head brass pipe plugs.
You can always just knock out an easy to reach freeze plug too.
A good coolant flush is almost the first thing I always do with an engine and these pics, although a worse case, shows why. The residue is still coming out after hours of flushing thru the block plugs.
BTW, when done this engine ran at a steady tstat temp, in S Florida, with no radiator foam pieces, oem brass radiator a stock fan, even idling in traffic when 95 outside.
Where I live, we don't have to worry about ever getting below a few degrees below zero and that's actually very extreme. I run mine full of straight A/F. My blocks are always clean and rust-free when I tear 'em down. Straight A/F freezes at a higher temp than the mix, but I'm not in an area that it would make any difference.
You have to get all the crud that settles in the lower cavities and if it has never been cleaned properly before, there will be a lot."
Once the plugs are out, how to you recommend flushing & getting all the crud out?
Try using the flushes and procedures available as a first step.
For serious flushing I remove the heater hose adapter from the intake manifold, replace with a brass 1/2"npt x 1/2"npt male hex nipple (http://www.hydrasun.com/catalogue/page.aspx?i=164)
If you can't get it at a local hardware, plumbing supply, try a hydraulic supply. Hex makes it easy for a wrench.
Then a 1/2" female npt ball valve (so you don't run to the shutoff valve 100 times), then a 1/2"npt male x female garden hose adapter (http://cgi.ebay.com/ws/eBayISAPI.dll...<br /> Remove both radiator hoses from radiator.
Use the hose full blast until it comes out the top radiator hose, then let drain completely. The surging under pressure from empty with the block holes open will help moving the crud to the holes.
Keep doing this till no more comes out. On one engine it took almost all day.
NEVER run cold water into a hot engine.
