Will I hit water?
Old Apr 30, 2010 | 10:29 PM
Simmo's Avatar
Simmo
Default Will I hit water?
Clearancing a 69 4bolt block for a 383 with 5.7 rods with capscrews. Looks like a fair bit of core shift and I have to grind heavily on 1 side but not the other. How close is water down there has anyone hit it? Its hard to accurately measure the thickness of iron at that point.
Old May 1, 2010 | 01:14 AM
Korevette's Avatar
Korevette
Hi Simmo,
I suspect you are grinding material for the rod clearance at the bottom of the cylinders to clear the 5.7 rod, is that correct?
I do not know for certain how far a water jacket would 'drop' down a cylinder wall but if you are grinding the bottom of a 'cylinder web' I don't think there would be water there although I maybe wrong. I think maybe a exploded view or cross section of a small block on the internet may help with seeing how far that water jacket goes down. Just a thought.
Dano,
