80 underhood light ???
Old May 2, 2010 | 12:16 PM
1980 blue L48's Avatar
1980 blue L48
Default 80 underhood light ???
My car had no underhood light when I got it. My hood has 2 holes for the light but no threads. Can someone descibe what type fastener to use. What was there from the factory? A photo would be great. I have had an aftermarket light for quite some time now, but haven`t put it on. I want a factory look. Thanks in advance.
Old May 2, 2010 | 01:08 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I've seen in the vendor catalogs and even in the AIM where they show threaded inserts.
But all four of mine, 78/79s, are simply screwed into the fiberglass.
Old May 3, 2010 | 06:30 AM
c3corvettes's Avatar
c3corvettes
My '80 used to have rubber grommet looking things inserted into the holes you're talking about. I'm pretty sure that they were factory installed. Being that they were made of a rubber material they have since been gone. I would also like to know how to affix the light to the hood and have a clean look.
Old May 3, 2010 | 08:39 AM
thegazman's Avatar
thegazman
Default thegazman
Here's a photo of my underhood light. I installed a small toggle switch in the fender well to turn the light off when I have the hood open for a prolonged period of time.
Old May 3, 2010 | 09:22 AM
Crash80's Avatar
Crash80
I was positive they were factory installed with pop rivets. Maybe I am on crack.
Old May 3, 2010 | 09:32 AM
hugie82's Avatar
hugie82
My 82 has small phillips head sheet metal screws. Now if I could just find the switch that turns it on and off when the hood is opened???
Old May 3, 2010 | 10:01 AM
Crash80's Avatar
Crash80
The switch is in the light itself. It is a mercury switch as I recall, the light knows what posititon the hood is in and it turns on or off accordingly. They are notorious for failing, thus many splice a real switch in the circuit.
Old May 3, 2010 | 11:48 AM
LABulldog's Avatar
LABulldog
I believe what you are looking for is called well nuts. They are a rubber coated nut with internal threads. Put the well nut into the opening on your hood, insert screw and tighten down. As you screw into the threads, the rubber expands and gives you a tight fit. I purchased mine from a hardware store and they work great. I want to say I got 1/2" well nuts but that was years ago. Just measure the opening of the hole on the hood and get the appropriate size.
Old May 3, 2010 | 12:43 PM
C3 4ME's Avatar
C3 4ME
When I removed mine, the well nuts wouldn't work to renistall them, so I wound up using the square inserts you get from the parts store to fit on a liscence plate bracket, that you would screw liscence plate screws into. They are in the HELP section of parts. They are hidden by the lamp and I was able to use factory type screws, so you wouldn't know it was mounted any different than factory.
Old May 3, 2010 | 01:09 PM
Smadoo's Avatar
Smadoo
On my 80 it's held in with 2 screws. I have no idea if that's the original way it was attached but it's been that way since before I got the car.
Old May 3, 2010 | 01:28 PM
hugie82's Avatar
hugie82
THANKS! That baffled the $hit out of me. I guess that explains why the bulb was removed.
Old May 3, 2010 | 02:08 PM
KapsSA's Avatar
KapsSA
The little cylinder by the C clip....
Old May 3, 2010 | 02:10 PM
Crash80's Avatar
Crash80
I was surprised to see that the switch is for sale by itself for about 13 bucks.
Old May 3, 2010 | 04:56 PM
boatdoc's Avatar
boatdoc
I also did this, seeing how we spend so much time under there!!!
Old May 4, 2010 | 09:46 AM
79blue's Avatar
79blue
I just completed this. Corvette Central part # 463032 $3.50 Perfect fit, made it real easy.
Old Jun 17, 2014 | 08:29 PM
atikovi's Avatar
atikovi
Found a whole page of well nuts at: http://www.clipsandfasteners.com/Nuts_Well_s/138.htm
Am I to assume an '82 would have standard fasteners, not metric? If so the largest screw that goes through the light is 8-32 and the holes in the hood are about 5/16". So that would be the forth one down on the right?
Old Jun 17, 2014 | 09:02 PM
TedH's Avatar
TedH
Ack. This thread is from 2010.
To 80 underhood light ???
Old Jun 17, 2014 | 09:22 PM
atikovi's Avatar
atikovi
That's what came up in a search.
Old Jun 18, 2014 | 10:31 AM
charleyahrens's Avatar
charleyahrens
My 81 has that exact setup. I was able to get replacements rubber grommets with a brass threaded insert at ACE hardware for a buck.
Old Jun 18, 2014 | 10:49 AM
atikovi's Avatar
atikovi
I just bought 25 of them on Ebay: http://www.ebay.com/itm/280619868166...84.m1439.l2649 Guess I can resell the extra 23 back on Ebay for a couple of bucks a pair.
