Mallory Unilite Help...Pulleezzzeee
Old May 2, 2010 | 10:22 PM
hawgn68's Avatar
hawgn68
Default Mallory Unilite Help...Pulleezzzeee
Ok, you electron guru's, I'm beggin'. I've got a Unilite with a Hyfire 6AL box. Was working great, then started shutting off after idle for 2-3 minutes. Now it won't fire at all. I've replaced the Hyfire, and hooked it up the same as the previous one...no fire. I tried bypassing the hyfire and still no spark. I've used different coils, no change. I'm stumped.
I've got 12.5 volts going to the pos of the coil and the red wire of the distributor. Likewise, I've got 12.5 volts on the green wire out of the distributor that goes to the neg terminal of the coil. However, there's no voltage accross the coil from terminal to terminal (+ to -) in either configuration with the Hyfire and without. On a different motor with a Pertronix, I get 9 volts accross the coil with the same test.
The cap and rotor both look fine. Before I replace the distributor, shouldn't there be voltage accross the coil witht he ignition on? Any ideas or further tests to determine my problem would be greatly appreciated. Thanks.
Jimbo
Old May 2, 2010 | 10:27 PM
1Fordman's Avatar
1Fordman
From past experience it sounds like the unilite module in the distributor has gone south. Go to the Mallory website and I believe there is a procedure sheet on checking the module.
Old May 3, 2010 | 02:43 AM
Solid LT1's Avatar
Solid LT1
Better yet put a Pertronix conversion into your Mallory distributor. I dealt with Unilites back in the 70's when I was working my way thorugh college in an auto parts store, lots of Unilite failures back then including one in my Boss 302. Had a 3 mile walk because of it, won't ever use one again!
Old May 3, 2010 | 07:46 AM
73StreetRace's Avatar
73StreetRace
I've got a Mallory Unilite module in my Delco distributor since 1990 and it's still working perfectly...
BUT, I only use it to trigger my MSD-6AL ignition box, so only a very small current goes through the module.
Old May 3, 2010 | 08:53 AM
tommyleea's Avatar
tommyleea
Put a Unilite in my Camaro in 1975, and it is still going strong. I would say in your case though, the module probably went south. I think I still have the box it came in.
TommyJ
Old May 3, 2010 | 09:20 AM
Roughrider's Avatar
Roughrider
A voltage spike can fry the module in a Unilite. Mallory sells an inline spike filter to prevent that. To me, if the problem is prevalent enough to make a filter to prevent it, Mallory should design the filter into the distributor or supply it as standard rather than make it an extra cost option. That's simply good customer service...it's easier than trying to regain customer loyalty once its lost.
Old May 3, 2010 | 10:27 AM
Kelso's Avatar
Kelso
I have never had any luck with anything from Mallory especally the Unilite Distributors. I have 2 hanging on the wall that I never got working. I know others will jump all over me for stating this but that is my history with the company and there products. My suggestion and this is only a suggestion is switch to MSD.
Old May 3, 2010 | 10:44 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
It's the module. I have Mallory Unilites in both my 61 and 65 and have had module failures in both. I'm sticking with points in my 68. There is a filter that Mallory sells to soften the electrical pulses to the module. That may help prevent future module meltdowns.
Old May 3, 2010 | 03:13 PM
Solid LT1's Avatar
Solid LT1
Anyone needing a cheap Unilte module, I have a few spares from a Vette I bought a few years back. $30 each, Email me at zeohsix@gmail.com. I'll test them on my friend's Sun machine before shipping but no guarantees!
I wouldn't wish one of these on a Mustang owner
Old May 3, 2010 | 09:40 PM
hawgn68's Avatar
hawgn68
Thanks for the words guys. I'll be getting a new module directly. The Unilite and Hyfire have been doing the job for 8 years on the race car, and my lousey wiring probably caused the failure (did have a lose wire on the switch panel). I love the built in rev limiter, and the fact that when working, it fires after 1/2 second of starter rotation. The only problem is that the diagnosis matrix has you checking the voltage accross the coil while interupting the opti sensor. Mine has no voltage accross the coil, but does to the green wire which attaches to the neg of the coil. That's what threw me.
Jimbo
Old May 3, 2010 | 09:51 PM
70BBvert's Avatar
70BBvert
Have a Unilite in my Mustang for the past 16 years with no problems. Sure does sound like the module went bad.
Jim
Old May 3, 2010 | 10:07 PM
LFZ's Avatar
LFZ
Classic case of a failed module. Just replace....as for the unilite itself, I have been using one for 5 years now with no problems on a 500hp 383.
Old May 3, 2010 | 10:15 PM
Frogday's Avatar
Frogday
This is the module I use in my Mallory Unilite: Summit Link, It is $40 instead of the $80ish one from Mallory.
Old May 3, 2010 | 11:14 PM
hawgn68's Avatar
hawgn68
Mallory actually has a cheaper E-spark module as well, 38 bones. We'll see if that fixes the issue. I'm cautiously optimistic!!
Old May 3, 2010 | 11:53 PM
snoopykissedlucy's Avatar
snoopykissedlucy
Another thought:
I have a Mallory magnetic distributor with no problems but listen to this:
My buddy buys one. He removes the cap to look inside. He goes to put the cap back on.
He ***** the cap to one side as he trys to snap it in place.
The little carbon button snaps off.
This button is designed to move in and out, but not flex.
If he had installed it, everything would look right but the button would have never touched the rotor.
Just sayin.............
Old May 4, 2010 | 03:31 AM
Frogday's Avatar
Frogday
Originally Posted by snoopykissedlucy
Another thought:
I have done the same thing, and the engine gives the illusion of wanting to start from time to time with that carbon button broken off.
Old May 4, 2010 | 08:22 PM
centralcalvette's Avatar
centralcalvette
Used to sell parts. We sold unilite modules to the unlucky, usually when their pride and joy died on what was supposed to be a great weekend. Funny thing is that those six or eight customers have scarred me for life, my "BABY" is getting a MSD and a "6" box. I didn't even consider a Mallory for MY pride and joy.
Old May 7, 2010 | 08:28 PM
hawgn68's Avatar
hawgn68
Update,
Replaced the module with a E-spark thingamabob for $38. Fired up immediately. The forum knows more than Mallory Tech Support!! Thanks guys.
Jimbo
Old May 7, 2010 | 08:53 PM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
Originally Posted by hawgn68
Update,
Jimbo
Glad you got it fixed. Enjoy the ride.
To Mallory Unilite Help...Pulleezzzeee
