TH350 transmission kickdown adjustment question
Old May 3, 2010 | 01:26 PM
teniselbow's Avatar
teniselbow
Default TH350 transmission kickdown adjustment question
I just replaced my Quadrajet with a Holley Street Avenger. I bought an adjustable cable linkage mount, but have not been able to find a setting on the kickdown cable that will make the transmission go into passing gear. It had no problem with the Quadrajet. Anyone know the secret of setting the cable to make the kickdown work?
Old May 3, 2010 | 04:27 PM
thegazman's Avatar
thegazman
Default thegazman
Hold the carbuerator accelarator all the way open and adjust the kickdown cable until the slack is gone. I had the same problem when I initially installed a Lokar kickdown cable to my 350 automatic.
Old May 3, 2010 | 09:04 PM
1nicecorvette's Avatar
1nicecorvette
he is correct. but you need to raise the clip first that is on the mount then pull the carb linkage open as far as it will go. then push the clip back down and let off the linkage
To TH350 transmission kickdown adjustment question
