Changing Diff Fluid
Old Mar 16, 2002 | 09:39 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Default Changing Diff Fluid
I went to the store today to pick up everything I should need to do this job. I got one quart of 75w90 Mobil 1 gear oil and two bottles of Limited slip diff additive. I plan on sucking the old fluid out with the pump tommorrow and filling it up. Is there anything I am missing or that might wrong??
Mark B.
Old Mar 16, 2002 | 10:18 PM
VETDRMS's Avatar
VETDRMS
Default Re: Changing Diff Fluid (Sigforty)
I would like to know if there is anything additonal or important to note because i'm looking at doing this this coming weekend.
anyone?
Old Mar 16, 2002 | 10:22 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
nothing else comes to mind. you pretty much described exactly what i did to mine about a month ago, except i put in redline. mine even saw some pretty heavy track time a couple weeks back and the last thing i was worried about was the diff. have fun! :smash:
Old Mar 16, 2002 | 10:26 PM
jerryp58's Avatar
jerryp58
Did someone say in a previous post about this that the additive was NOT necessary if synthetic fluid is used :confused:
Old Mar 16, 2002 | 10:34 PM
IronJen's Avatar
IronJen
Abby Normal
Default Re: Changing Diff Fluid (jerryp58)
i don't know about synthetics in general but redline advertises that it is not necessary with their fluid. i have been running it for about three years now and have not noticed any clutch chatter or unusual whining from the gears. you could probably search mobils site and they might say if it's o.k. to run w/o the additive.
Old Mar 16, 2002 | 10:35 PM
GTR1999's Avatar
GTR1999
I was told this week by a guy at Tom's, in CA, not to use synthetic oil because it wil cause problems in the differential. They recommended the GM additive and Lucas 90-145 oil. A few folks here use the synthetic and haven't had a problem. I last used Valvoline 90wt that was supposed to be good with posi's and had more knocking then ever. I'm going to drain and try either the Lucas or go back to GM oil.
Gary
Old Mar 16, 2002 | 11:24 PM
rhoeven's Avatar
rhoeven
Jerryp58,
Redline 75W90 has already limited slip additive in it. They have also a 75W90NS which has NO additive in it.
I use the 75W90 in my '81 and have no problems at all.
Hope this helps
Roger
:cheers:
Old Mar 17, 2002 | 07:36 AM
GaryS's Avatar
GaryS
You got it all. I would drive the car for a few miles to warm the stuff up. Otherwise, it is like trying to suck out split pea soup.
As far as the other posters and what to use, I have been using Mobil 1 sytnthetic differential oil for quite a while now. If I didn't like the Mobil stuff so well, the only other one I would use is the GM brand of differential oi. I also add two containers of GM positraction additive from the Chevy dealer. There is a guy not far from me who rebuilds differentials for a living and he likes both GM and Mobil oils. He also says to use the GM brand of posi additive.
Gary
Old Mar 17, 2002 | 08:20 AM
jerryp58's Avatar
jerryp58
Default Re: Changing Diff Fluid (rhoeven)
Roger, Thanks. I had my diff fluid changed last year, but the guy said it was kind of "murky". I figured it'd be pretty easy to do with my spare out of the way, so I'm going to change it myself and see what it looks like after a year. I haven't decided about synthetic or not.
Mark B., good luck & please post how you make out.
Old Mar 17, 2002 | 12:25 PM
Sigforty's Avatar
Sigforty
I just woke up about 30 minutes ago and am getting ready to change the fluid. Thands for the info and reassurance I am heading the right direction. I will let you know how it went after I finish.
Mark B.
To Changing Diff Fluid
