Holley Avenger - Choke Pulloff
Old May 5, 2010 | 10:10 AM
bigvette1's Avatar
bigvette1
Default Holley Avenger - Choke Pulloff
I posted a while back on how to adjust the choke pulloff on a Holley Avenger carb. This is applicable to all series of the Street Avengers. The thought was to use the method of the 4160 carb per the Holley instruction sheet. Not so. The pulloff piston inside the choke housing has an external screw buried under some putty on the outside of the piston chamber that will adjust the amount or opening of the choke plate. Dig it out and adjust CCW to increase the opening at start up. Just an FYI
