Gears -- 3.08 vs 3.70
Old May 6, 2010 | 09:24 AM
LOTSARED's Avatar
LOTSARED
Default Gears -- 3.08 vs 3.70
Hey all -- My '68 runs a stock close ratio Muncie and 3.70 rearend. I love the low end grunt, but tired of the hi-rev highway cruising.
I'd appreciate any thoughts on swapping out the rear gears with a set of 336's or possibly even 308's.
Will I notice the loss of low end thrust much? Will the 65 mph cruise be much more relaxed? And roughly how much $$ to have this swap done?
Oh, background info... engine is a mildly modified L36 427 (bored/stroked to 463, street/strip cam, Edelbrock performer rpm heads, stock manifolds, and magnaflows).
Thanks in advance--
Old May 6, 2010 | 09:34 AM
gingerbreadman1977's Avatar
gingerbreadman1977
Will I notice the loss of low end thrust much? yes you will, with 3.08 say goodbye to hard launches, it will be gone. Will the 65 mph cruise be much more relaxed? for the hiway it will be purring along and become a real nice cruiser on the open road . it will prob sit on about 2200 rpm at 60mph. And roughly how much $$ to have this swap done? very little . a shop would put them in for a few hundred and the gears im guessing would only be a couple hundred as well.
Thanks in advance--
you need to make the decision taking into account what you do more often...hiway or around town.
Old May 6, 2010 | 09:40 AM
dw5555@charter.net's Avatar
dw5555@charter.net
Personally, my 454 with 308 is fine. BBC have a ton of torque and will get you moving w/o a problem. You will notice a difference on take off but if you're tired of the highway buzz swap to 336/308, your motor will thank you for it. Probably close to 500 rpm diff at 70 mph.
Old May 6, 2010 | 09:52 AM
Richard454's Avatar
Richard454
With 255/60-15" tires- or about 27" diameter-
The 3.08 rear will be about 2500RPM...@ 65MPH
The 3.70 should be about 3000RPM.
So about 500 difference as DW5555 said...
There's a lot of tire/ratio/speed calc out there-
http://wildcatent.freeyellow.com/zookmods/calc.htm
My 71' LS5 came from the factory w/ a 3.08- I don't think you'll have any problems.
Richard
Old May 6, 2010 | 09:53 AM
Snoopysvet's Avatar
Snoopysvet
Keisler.com
Old May 6, 2010 | 10:12 AM
bashcraft's Avatar
bashcraft
I'm going to be swapping my current 3.55 gear for a 3.08 this weekend for the same reason as you. I have a 502 so I'm sure it'll be fine.
Old May 6, 2010 | 10:15 AM
LOTSARED's Avatar
LOTSARED
Default workin on a budget
Originally Posted by 98MustGT
Keisler.com
... sure thing. I plan to visit keisler.com soon after ijustwonthelottery.com .
Old May 6, 2010 | 10:16 AM
LOTSARED's Avatar
LOTSARED
Default keep us posted
Great! If you don't mind, please post your reactions to the swap after you've done it. Thanks-
Old May 6, 2010 | 10:20 AM
Clams Canino's Avatar
Clams Canino
Keisler.com
I was gonna say this. the best of both worlds is the 5 speed OD.
You get to keep your bottom end yank - and yet cruise at a decent RPM.
-W
Old May 6, 2010 | 10:36 AM
ajrothm's Avatar
ajrothm
LOL
I think the 3.08 will be fine with your big block...unless you are trying to extract every last tenth at the strip...you will be happy with the 3.08s.... If you are a "spirited" driver, go to 3.36s but the highway cruise won't be as nice....
FWIW... I have 3.08s in mine. My car is an Auto and I have a stall converter so it skews my RPMs some but.... At 70 mph(gps verified), I turn 2950rpms, 75mph is 3150rpm, 80mph is 3300 or so.....I believe 85 mph was 3500. Very liveable... Ofcourse my converter really helps the acceleration from all speeds and my motor makes a LOT of torque....but my 60's at the strip are still decent at 1.61 on 27" tires...w/3.08 gears.
Good luck on the gear swap...3.08 or 3.36s will be fine.
Old May 6, 2010 | 10:37 AM
Les's Avatar
Les
You just need to decide how important it is for you to pull hard off the line vs. cruising easier at speed. You will notice a difference in acceleration no doubt. Your street/strip cam could be the critical factor here because if it's near the edge for streetability your rear gear change could make throttle response a bit soft with that 2.20 first gear in your trans vs. the 2.52 that comes with the wide ratio trans. What are the specs on your cam? FYI, I went from 2.73s to 3.55s and it was night and day but that's with a TH400. However, I don't take many trips in that Vette.
Old May 6, 2010 | 04:36 PM
Vesa's Avatar
Vesa
3.08 will be good for you with that torgue. You still spin the tires on 1 2and 3 gears I bet...
Old May 6, 2010 | 04:41 PM
avner's Avatar
avner
I changed my deff' from 4.11 to 3.36, the RPM go down by ~600RPM, but in first I tried to change only the pinion/ring and it didn't fit in the original case, I was told that the higher ratios (4.56,4.11...) had deferent cutting inside the case so I changed complete deff'.
Avner
Old May 6, 2010 | 05:04 PM
dw5555@charter.net
I'm not sure but I thik 3.91 and up use a different case. Don't quote me though.
Old May 6, 2010 | 05:36 PM
Vesa's Avatar
Vesa
4.11 and up is different than 3.9 and down...well that is what you just saidi´m slow...
Old May 6, 2010 | 06:33 PM
Corey_68's Avatar
Corey_68
you'll be fine with 3.08's, I have no ambition to swap to 3.70 with my big block.
Old May 6, 2010 | 07:30 PM
hugie82's Avatar
hugie82
I had 3.08 in my 74 with a BBC 427 and a 4 speed. Excellent street car
To Gears -- 3.08 vs 3.70
Old May 6, 2010 | 10:55 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Can't tell where your located.
Thanks in advance--
FYI i still have my stock 3.23 ring and pinion (now have 3.70 gears). Located here in So California. Where are you?
BTW do you have an extra close ratio muncie for sale?
cardo0
Old May 7, 2010 | 11:18 AM
1ARACE's Avatar
1ARACE
Another option, is an overdrive/wide-ratio kit for your Muncie. I have 4.56/4.88 gears in mine and it brought it up to a 3.91 final drive ratio.
I bought mine from www.autogear.net.
The wide ratio kit for 3.70's is ~$700-800.
It wasn't too hard to change the gears either.
Old May 7, 2010 | 02:17 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
Yeah, I think your close ratio is where the issue is. I have a 454 with a 3.08 and the wide ratio. I have no trouble smoking the tires in first, screeching in second and chirping in third, even though I have never gone out of my way to do this. 65 mph cruise is at 2600 rpm, so that isn't bad. I wouldn't go so far as to say I "like" my 3.08, but it is plenty fine for street driving, which is what I use the car for 100% of the time. If I got into drag racing, I am sure I would change the rear, but for street driving, it is fine.
