1/4 mi time estimate
383 stroker with forged pistons (approx 9.8:1 cr)
Canfield 197cc al. head assembled w/roller springs, cnc chambers, blended bowls, port matched, 2.08/1.6 valves
224/234 @ .50 .499/.502 lift 112 cl
roller tip rocker arms
770 cfm Holly Street Avenger
Performer rpm intake
Stock HEI w/pertronix kit
8 mm plug wires
hv oil pump
1 5/8 headers
windage tray
6 qt baffled oil pan
* will add 150-200 hp NOS at a later date(Power thirst quincher)
Since all of these numbers were generated by a computer, not real world, they are suspect. The canfield heads have great flow numbers and they have been ported and gasket matched to flow even better. Comparing these to AFR's, they outflow a STOCK 195 head. With a 218/223 cam, AFR's made 440hp and 470tq. Stepping up, a 230/236 cam made 491hp and 501 tq. my DD guestimated numbers are right in there.I could go to a larger cam, but street manners are very important.( the ol' lady wants to drive too) I would hate to spend all this cash and end up with great specs and no guts.
For reference: http://www.ryanscarpage.50megs.com/afr.html
[Modified by newonad, 2:38 PM 3/17/2002]
The only thing I could figure about the 1/8 mile speed is that at half track the other car and I were neck and neck. Perhaps that confused the timing system.
Regarding prepping graphics for display on the web in general, one trick I've found that helps is to scan the image at a much higher resolution than needed, correct exposure, sharpen, then downsample the image as the last step. I use Adobe Photoshop and Irfan View.
-Noel
[Modified by Noel Carboni, 3:34 PM 3/17/2002]
anyway Newonad your setup is almost exactly mine
Check out my sig for details...
I havent run the track yet with this motor but from the feel I would guess high 12s. With my wide ratio M20 I can do 0-60 in 1st gear.. :D in about 4 - 4.5 seconds. I have 3.36 rear and this is killing my launch. I want 3.73 or 3.90s.
:flag
[Modified by Clink69, 4:53 PM 3/17/2002]
Anyways I'm selling my heads and moving up to some AFR 210s, going with a Holley Stealth Ram EFI system, a 236/242 hydraulic roller, hoping for a 500 hp beast which pulls to 6500 no problem, and low 12s or high 11s with some 275/60/15 drag radials. I've now upgraded to 4.11s, VB&P smart struts & dual mount rear spring, HAL adjustable shocks, and a X pipe exhaust. I have pics and info and things I would have done differently on my website:
http://ese.dwdata.com/rob/car.html
Rob
