Courtesy light delay unit
Old May 6, 2010 | 06:42 PM
pepegriffo's Avatar
pepegriffo
Default Courtesy light delay unit
I just purchased a new courtesy light delay unit. Connected the unit to the plug and play connector, lights came on. I waited several minutes they would not go off.
Lights work with the headlight switch. Started the engine to see if that would trigger an off cycle, nothing.
I appreciate any suggestions thought on what might wrong.
My vette is an 1981
Pepe Griffo
Old May 6, 2010 | 06:57 PM
straub18045's Avatar
straub18045
possible door switch faulty?
Old May 6, 2010 | 06:59 PM
...Roger...'s Avatar
...Roger...
Is it orange in color ? Is it new or used or rebuilt ?
If unplugging it turns the lights off then it is the unit that is keeping the ground circuit grounded, bad unit.
I will check the 81 courtesy light wiring diagram and see if there is anything else but I doubt it.
Old May 6, 2010 | 07:03 PM
...Roger...
Straub is right. I was for some reason thinking you had bypassed by jumpering the whites and the system worked normally. :o Too many threads !!!
Old May 6, 2010 | 07:38 PM
pepegriffo's Avatar
pepegriffo
Thanks for the replies.
I will check out the door switch. I have already replaced the pass. side switch. How could I check t see if the switch is indeed bad?
Pepe Griffo
Old May 6, 2010 | 10:16 PM
...Roger...
If you remove the controller and put a jumper between the white wires the system should operate like a non-delayed interior light system. If the door switches operate normally then they are OK.
Make sure the GAUGES fuse is not blown.
Old May 6, 2010 | 11:02 PM
pepegriffo's Avatar
pepegriffo
Thanks a lot Roger I will try your suggestion.
Again thanks
Pepe Griffo
Old May 7, 2010 | 08:48 AM
straub18045
i did this permanently because i was tired of waiting to see if the lights would actually go out
To Courtesy light delay unit
