Undercar Aerodynamics Question!
Old May 7, 2010 | 03:09 PM
Bee Jay's Avatar
Bee Jay
Default Undercar Aerodynamics Question!
A friend of mine said that the inside of my car looks like a goat exploded in there. So I'm ripping out the old carpet up front, and like the back I did a couple of years ago, I'm covering it with fatmat and felt before I lay the new carpet in. Then I discovered this.
About 20+ years ago, when I installed the 700R4, the driveshaft u-joint was hitting the trans tunnel side, so I had to cut out a little hole. I covered it with duct tape and carpet and forgot about it. Of course yesterday I covered it with an aluminum plate and rivited it in, and glued over it with heat barrior and felt.
But the other morning I drove the car to work with the hole uncovered. Holy Moly, the air flow from that hole was tremendous. At 60-70 mph, putting your hand over this hole was like sticking your hand out the window. It was a cool morning but the air comming thru the hole was very warm. So obviously it had come thru the radiator. So I'm wondering, how does air come thru the radiator, around the engine, and into the trans tunnel, with so much force and velocity. The tunnel does start wide and get narower, but man, it was like an air dryer on high. Maybe the rotating u-joint acts like a propeller? Any ideas?
Bee Jay
Old May 7, 2010 | 08:34 PM
Bee Jay's Avatar
Bee Jay
Anyone?
Bee Jay
Old May 7, 2010 | 10:04 PM
72LS1Vette's Avatar
72LS1Vette
C3's were designed in a styling studio rather than in a wind tunnel so there propably wasn't much thought given to airflow under the car. The trans tunnel is sort of shaped like a backwards NACA duct so maybe that has something to do with the high velocity air. You were probably getting some fan effect from the rotating U-joint also.
Rick B.
Old May 7, 2010 | 10:32 PM
noonie's Avatar
noonie
There is a foam piece that sandwiches between the tunnel and the bell housing on some to prevent most of this.
Old May 7, 2010 | 11:55 PM
Bee Jay's Avatar
Bee Jay
Really? I've owned my car since new and never saw anything like that. But it makes sense. Is it just shoved up in there or is it attached somehow? I think I am even more convinced to vent my hood. The air coming into the car definitely had been thru the radiator.
Bee Jay
Old May 8, 2010 | 12:00 AM
noonie's Avatar
noonie
The real Shelby 428 Mustangs and even the Viper hoods are vented.
Old May 8, 2010 | 01:52 AM
Lt1er's Avatar
Lt1er
Lots of air flow through the rad which creates pressure under the car. I had a torn shifting boot and it would feel like a blast furnace in the summer. The stock hole throught the tunnel was way too big. Like your self made hole!
Old May 8, 2010 | 09:01 AM
noonie's Avatar
noonie
Here is a link for the foam piece
http://www.ecklers.com/product.asp?p...3&dept_id=1457
Old May 8, 2010 | 09:35 AM
dw5555@charter.net's Avatar
dw5555@charter.net
Is this in the AIM, I don't recall ever seeing one?
Old May 8, 2010 | 09:52 AM
Bee Jay's Avatar
Bee Jay
Thanks Noonie. I guess it was a bad day at the factory when my car was built. I did not have that. Should be easy enough to duplicate.
Bee Jay
Old May 8, 2010 | 10:02 AM
noonie's Avatar
noonie
Haven't opened an AIM in years, but I remember some of the early cars having them. My 75 still has the foam on the frame rails, but no tunnel foam.
I'm sure these were one of the first pieces to disappear, like the starter heat shields, rear braces etc etc.
Old May 8, 2010 | 10:17 AM
mrvette's Avatar
mrvette
Dark gray foam water pipe wrap from Lowes Despot....
5 bux worth....3/4" pipe....
also check to see the shifter boot is sealed good...
Old May 8, 2010 | 10:47 AM
oldsarge's Avatar
oldsarge
My 73 had the tunnel foam, it is in the AIM, sometimes because of wind and wear, they just blow away.
Old May 8, 2010 | 05:10 PM
vette427-sbc's Avatar
vette427-sbc
Bee Jay- Check out these links here... Some interesting reading-
http://www.autospeed.com/A_2159/cms/article.html
http://www.autospeed.com/A_2160/cms/article.html
http://www.autospeed.com/cms/A_2162/article.html
And more aero links here:
http://www.pro-touring.com/forum/showthread.php?t=61936
PS- did you happen to get the weight of all the fatmat you put down? Ive been hesitant to put some under my carpet because of the weight. I must have put over 20lbs of it in my fathers car (55 chevy= lots of floor pan to cover). It sure makes a huge difference in road noise, but Im trying to stay in the sub-3000lb club.
Old May 8, 2010 | 06:47 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I just stuffed some pipe foam / insulation in there when I swapped my tranny, my lower shifter boot was ripped and I never noticed anything, I just recently put a new shifter boot in there and there is no noticeable difference.
Why not rivet some sheetmetal under the car and make it flat under there like racecars ?
Old May 8, 2010 | 09:53 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Agree with what 72LS1Vette is saying that the tunnel's profile is probably causing somewhat of a venturi effect.
IIRC that foam piece was deleted circa '76, but one is going in my '78 when I get it put back together.
Ran for a while without the lower shifter boot after converting from auto to manual, and IMHO there was a lot of hot air draft into the cockpit.
Got a few mods planned for addressing undercar air, including my own version of a splitter similar to yours (Bee Jay), functional fender well vents above the front tires, very possibly enlarging the engine compartment side vents, and more, but really want to take pressure readings first (have the instruments ) so that I'll have before and after data. Not so sure I wish to cut up my hood to open up vents, but shy of hard data on the C3 I've seen indications from other vehicles that just aft of the rad, rather than near the base of the windshield, is probably the best location for such.
Old May 9, 2010 | 06:52 AM
Bluey's Avatar
Bluey
I guess the Trans Tunnel takes the shape of a Convergent Duct and according to bernoulli's theorem...Air Velocity increases as it goes through a convergent duct...maybe thats why the force felt so great....it probably was !!!
Old May 9, 2010 | 09:08 AM
Bee Jay's Avatar
Bee Jay
Not sure how much the fatmat weighs under the carpet, but with my exhaust system so loud, I felt to heck with the weight. I even put down a layer of felt on top of the fatmat. The shipping weight of the fatmat was lower than 20lbs if I recall correctly (IIRC).
Bee Jay
To Undercar Aerodynamics Question!
