Aero Kit
Old May 8, 2010 | 03:39 AM
qboy's Avatar
qboy
Default Aero Kit
Any aerodynamic body kits that will get some good downforce (front & rear) that won't break the bank?
Old May 8, 2010 | 02:36 PM
qboy's Avatar
qboy
I saw Ecklers has a front chin spoiler but I'm not sure how much effect it has. Also, probably need to get a rear one that works.
Old May 8, 2010 | 05:29 PM
7T3C3TTZ07's Avatar
7T3C3TTZ07
The Sundowner (1969 turbo L88) was able to stay on the ground at 240 MPH with a fairly simple chin spoiler. http://www.mitechengines.com/picture...s%20page-8.htm
Old May 8, 2010 | 10:24 PM
qboy's Avatar
qboy
I'm thinking about 28.8" tall rear with 26.5" tall front tires plus a chin spoiler. I'd also like any advise anyone has to keep this thing safely on the ground.
Old May 9, 2010 | 09:26 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Just so you're aware, the Pace Car dam & spoiler kit are sound functional designs, but if you go with an OEM my experience is you'll have to brace the dam to keep it off the ground if you intend to do any real speed. Don't expect that much of a difference below ~100, but by the time you get up to ~120 you should notice a growing improvement in how you can take high speed sweepers (assuming everything else is in order). Not condoning you breaking any laws here.
Another thing you ought to do is lower your ride heights to Chevy Power specs with a little rake dialed in (don't get rediculous or you'll screw up your CG heights and suspension geometry). Also, to keep from upsetting your car's aero balance front to rear I wouldn't suggest going with only a dam or spoiler separately.
You might find the thread below interesting...
http://forums.corvetteforum.com/c3-t...ics-et-al.html
TSW
To Aero Kit
