383 stroker with turbo?
Old May 9, 2010 | 03:25 PM
xemilliox's Avatar
xemilliox
Default 383 stroker with turbo?
I have recently stroked my 78 to a 383 and put a 700R4 tranny behind it. I am thinking about adding a turbo to it but was wonering if anyone out there has done this before and if so what upgrades would I need to do? Thanks for the help.
Old May 9, 2010 | 03:47 PM
Lt1er's Avatar
Lt1er
The 700R4 is weak link unless you have one of the racing 750-850 hp units. Really the whole car is a weak link and once you exceed 600 hp about the only thing original might be the body
Old May 10, 2010 | 03:51 AM
enkeivette's Avatar
enkeivette
LT1er is right about the trans, nothing else. Big G just put down 625 WHEEL HP through a stock diff on 325 drag radials. I'm putting out prob about 700 flywheel hp, also stock diff.
You just need to upgrade the u-joints and get some stiff springs and decent shocks.
There are a few guys in here that have done turbos. The easiest solution is a roots blower or a centrifugal blower.
No one makes a kit, so you'll need to get turbo manifolds for a SBC and figure it out yourself. Clearance with the brake booster will be an issue with a dual turbo setup, big single on the pass side is the way to go.
http://www.youtube.com/watch?v=--bOUCKtTiw
Old May 10, 2010 | 06:51 AM
enkeivette's Avatar
enkeivette
Almost forgot about TT
http://vettemod.com/forum/showthread...7644#post67644
Old May 10, 2010 | 07:46 AM
mopkop's Avatar
mopkop
Default weak link
Then all Corvettes must be a weak link,The 1978 is more or less the same as the rest
Old May 10, 2010 | 07:49 AM
mopkop's Avatar
mopkop
Default 700 R4 gearbox
I do not want to higjack your thread ,please send me info to mopkop@netvigator.com concerning 700 R4 swap
J Smit
To 383 stroker with turbo?
