anyone have desktop dyno?
Old Mar 17, 2002 | 01:36 PM
lyndave75's Avatar
lyndave75
Default anyone have desktop dyno?
I was wondering if someone could dyno my new engine for me. Most of the components can be found in my signature, but here is some additional info: cam specs:Ertyl cam# 115871, cam lift .339 int, .355 ex, lobe ctrs 107 int 117 ex, lash hot hyd, sae dur.313 int 328 e, .50 dur. 244 int 254 ex, ignition is GM hei, Edelbrock rpm heads have 72cc chambers. If any additional info is required please let me know. Any help is greatly appreciated. :cheers:
Old Mar 17, 2002 | 02:11 PM
Aaron-74's Avatar
Aaron-74
Default Re: anyone have desktop dyno? (lyndave75)
I need your valve size...2.02/1.60 1.94/1.50?
Old Mar 17, 2002 | 03:32 PM
bence13_33's Avatar
bence13_33
I punched the data into Desktop Dyno and it has you making 400 horsepower @ 5500 RPMs, 413 torque @ 4500 RPMs. The numbers might be slightly more but I didn't have the cam file so I had to punch in the numbers. Also, I wasn't sure what type of cam this is hydraulic, solid etc... so I used a solid lifter cam. I also used 2.02/1.60 valves because I believe those are the valves in the Edelbrock RPM heads correct?
Old Mar 17, 2002 | 04:49 PM
Aaron-74's Avatar
Aaron-74
With that EXACT motor and cam I got..
Hyd. cam. Edelbrock Perf. Heads. Dual plane intake. Same cam specs. CFM. Exhaust....
420HP@5500
482LBS@4500
[Modified by Aaron-74, 2:56 PM 3/17/2002]
Old Mar 17, 2002 | 05:06 PM
Aaron-74's Avatar
Aaron-74
Default Re: anyone have desktop dyno? (Aaron-74)
Car Test says
0-60: 4.2
0-100: 9.9
1/4: 12.5@115.8
Granted- those aren't truley realistic numbers. It's a "ball park"
That was done on stock 1977 Vette spec with a 4 speed and a 3.70 rear. 255/60/15 tires.
Old Mar 17, 2002 | 09:05 PM
lyndave75's Avatar
lyndave75
The valves are 2.02 & 1.60 , and it's a hydraulic cam. Thanks for the replies.
To anyone have desktop dyno?
