jacking up rear
Old May 10, 2010 | 10:27 AM
8888vette's Avatar
8888vette
Default jacking up rear
Guys
were would be a good location for me to lift the car from the rear both sides at the sametime
thank you
Old May 10, 2010 | 10:30 AM
dembo's Avatar
dembo
I always use the diff pumpkin, with a thick MDF plate in between the diff & jack. Never had any probs so far and believe me the last couple of months I've done it frequenty. (I do open all doors, unlatch hood and T-tops)
Nick
Old May 10, 2010 | 11:03 AM
TWINRAY's Avatar
TWINRAY
If I need the whole rear end up, I do one side at time and put jackstands under the side frame at the recommended points in the manual when doing a tire change.
Old May 10, 2010 | 10:35 PM
vettehardt's Avatar
vettehardt
I jack up on the plate holding the rear spring to the diff. I then put jack stands on the frame in front of the wheels.
Old May 10, 2010 | 11:31 PM
fwillison's Avatar
fwillison
excellent question
I've jacked up one side at a time and put jackstands under the frame in front of rear wheels.
Same for the front, just behind the front wheels.
I know some people use the diff pumpkin. Not sure if that is a problem or not, but not specified in service manual as an option.
Old May 11, 2010 | 10:30 PM
8888vette's Avatar
8888vette
guys ;
thanks for the replys
Old May 12, 2010 | 01:16 PM
Rally68's Avatar
Rally68
I've tried it many ways and this is the best: place a 6" piece of 2x4 on the jack cradle and jack right under the rear spring mount. There's a bolt that holds the spring leaves together, it protrudes through a circular hole in the spring retainer plate. The end of the bolt will punch into the wood, holding the wood in place and protecting the end of the bolt. The wood keeps you from nicking or scratching anything back there, and you are free to place the stands anywhere along the frame. When I jack using the frame, I usually find I can't quite put the stand where I want because the jack is in the way...
Old May 12, 2010 | 06:14 PM
jordan89's Avatar
jordan89
Old May 13, 2010 | 05:40 PM
Neptune75's Avatar
Neptune75
Or just install a lift!
Old May 13, 2010 | 08:24 PM
crazcorkath's Avatar
crazcorkath
I lift it up on the differential and then block it about 6" or so in front of the wheel well on both sides
To jacking up rear
