My Flex-o-Lite set up
Old May 12, 2010 | 08:42 AM
hugie82's Avatar
hugie82
Default My Flex-o-Lite set up
Damn! the pic didn't work
This was for the guys who were asking about electric fans. So they can see how clean it looks. Not physically clean but you know...LOL
Old May 12, 2010 | 08:45 AM
hugie82's Avatar
hugie82
http://s283.photobucket.com/albums/k...0.jpg&newest=1
Here we go I think?
Old May 12, 2010 | 09:53 AM
Letournour 1850's Avatar
Letournour 1850
same fans I have work well, were did you put the thermo sensor or do you have a block sensor
Old May 12, 2010 | 11:20 AM
John 65's Avatar
John 65
Here ya go ! Looks nice.
Old May 13, 2010 | 01:34 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Nice work, looks like a stock item.
What are u using for a controller and what are your temps?
How much $$$?
Congrats,
cardo0
Old May 13, 2010 | 07:59 AM
ssenay72's Avatar
ssenay72
How did you mount it? Did it come with mounts that fit without mods or anything else? The universal mounts that most of these come with just dont work well. What model number is it also.
Old May 15, 2010 | 02:51 PM
hugie82's Avatar
hugie82
Sorry guys I didn't have a PC for a few days. The mounting tabs bolted right to the shroud bolt holes with very little tweaking. The thermostat is the adjustable one that comes with the flex-o-lite fans. Temps stay at 180 for normal driving. In traffic it will come close to 200 with the A/C on.
The only up grade I would suggest is a 100amp alternator. I would never hit 200* if I had a better alt.
Price in the Summitracing with thermo is @$350
Off the line torque is a big improvement and gas mileage was up too.
Old May 15, 2010 | 04:48 PM
jordan89's Avatar
jordan89
Looks very good. I've been thinking about going with electric fans myself, but just haven't had time to do so. What's the part# for those?
Old May 15, 2010 | 06:02 PM
ssenay72's Avatar
ssenay72
I think they discontinued the 210's and replaced it with the 410. Thats what I ordered last night. basically the same thing.
Old May 15, 2010 | 06:14 PM
jordan89's Avatar
jordan89
Thanks.
Old May 17, 2010 | 08:52 AM
hugie82's Avatar
hugie82
Yes that is correct FLX-410. The price jumped about $100 in the past 5 years but its worth it I was able too hide the thermostat down the drivers side fender next to the radiator. I'm pretty sure it's the probe type that slides in the upper hose? I forget, it's been over 5 years. I can get my car down to 160 if I change out the thermostat but I'm running fuel injection (Crossfire) so the idle will come up sometimes. I run a 190 thermo now.
If you have an 80 or older vette I strongly suggest a 100amp alt. if you run A/C. The fans will run with the old Alternator but at night with the headlights, A/C, radio, ect,... You'll see that volt gauge look very low
My 82 has an old 70amp and it is maxed out under heavy load conditions but the car will not overheat but it will creap up to 210-220*
GOOD LUCK Everybody And keep those electrical connections clean, tight and shrink wrapped!!!
Old May 17, 2010 | 02:01 PM
Rmorgan&11's Avatar
Rmorgan&11
[QUOTE= [B]The only up grade I would suggest is a 100amp alternator. I would never hit 200* if I had a better alt.[/B]
Remove that chunk of belt driven HP Robbing smog pump and run another one in its place !
2's always better than 1 right ??
Old May 17, 2010 | 02:11 PM
hugie82's Avatar
hugie82
[QUOTE=Rmorgan&11;1574098818]
I keep the smog pump because I was still going through inspection in New Jersey back then. Now, I'm just too busy, too lazy and avoiding a check engine light
Old May 17, 2010 | 02:16 PM
hugie82's Avatar
hugie82
My NAPA 100amp alt. is sitting on the shelf and is all ready to go if the stock one craps out. As of now that little sucker just hangs in there. When I changed the battery to an Optima red top my alt seemed to be happier but for how long
LOL
Old May 18, 2010 | 03:39 PM
cardo0's Avatar
cardo0
Default Great info!
Thx for posting your info and results hug. I'm looking a resonable conversion to run Gen II and other motors without a fan clutch. $350 is very reasonable but hoping to find a salvage conversion like from a Gen 4 Camaro or something.
Got your info ready on file now.
Thx again for responding.
cardo0
Old May 18, 2010 | 06:01 PM
ssenay72's Avatar
ssenay72
my 410 should be here tommorow, ill probably find time to do it this weekend.
hugie82's Avatar
hugie82
cardo0
That's CoolI'm glad I could help. I tried getting fans from other cars but it seemed everyone had a special curve or bump in the shroud that made it look like $hit...
Also if you look close you will see the flex-o-lite fans have a very soft round seal that bumps up perfect on all 4 sides.
Good Luck
To My Flex-o-Lite set up
