After a search of the forum I have learned the green wire is for the temp sending unit on the block. Where does the black wire that I think is a gound go? It has a large eyelet connector so it must bolt to something?
Or if it's on the passenger side it could be the ground for the wiper and blower motor and it attachés to a starter bolt or better yet attach it to a bell housing bolt.
After looking at your picture I am sure it is the large ground wire. I found a place on the powermaster alt. to attach it. The car is a 71 350 but I have put a 383 crate motor in it and I am finding that everything is different. I will have more wiring questions as I go along. The search feature helps because more of experienced peope like you guys....thanks
Great, if you need any other pix let me know. I have a 71' 350 along with a camera. You can just send me a PM when you need something.
