How To Replace High Beam Dash Light Bulb?
Old May 15, 2010 | 02:11 AM
78 C3 Light Corvette Blue's Avatar
Acct suspended by request 19 April 2011
Default How To Replace High Beam Dash Light Bulb?
Has never worked since I have had the car 3 years now. Was low priority. Now want to replace the bulb. It's a 194 I know. How much of the dash has to be removed?
Thanks Gary
Old May 15, 2010 | 07:49 AM
78pace's Avatar
78pace
all you should have to do is: 2 bolts and drop column down... remove plastic cover over speedo and tach..... reach up under dash push down on clip that holds speedo cable and pull back cable.. then you can remove speedo and tach housing from dash. The bulbs just twist into housing and contact the circuit paper/plastic board. Pretty straight forward on the 78
