WOW !!! WHAT A DIFFERENCE...........
Old Mar 18, 2002 | 12:11 AM
vettecor's Avatar
vettecor
Default WOW !!! WHAT A DIFFERENCE...........
a new rearend can make. I just had the Richmond 3:70 installed in my '77. I had the original 3:08 in my automatic TH350, and was sick of the no power at takeoff. The car feels like I have a new engine.
I have only driven it once since the install, so I'm not quite used to the high RPM's cruising at 70 MPH. My mechanic assures me that going on out of town trips of around 300 miles will NOT hurt the engine!
I'm going to Easley South Carolina next month for the POKER RUN and don't want to have problems!!!!!!!!!!
Thanks for listening.
Larry :seeya
Old Mar 18, 2002 | 12:38 AM
C3Vettesrock's Avatar
C3Vettesrock
Default Re: WOW !!! WHAT A DIFFERENCE........... (vettecor)
what rpm u turning at 70?
Old Mar 18, 2002 | 12:40 AM
Shark Racer's Avatar
Shark Racer
If you plan on taking a lot of freeway trips, 700R4 or 2004R is the way to go with that rear gear. Driving in 4th would be like driving in 3rd w/ a 2.59:1 ratio. I have 3.55s in my car, and I must say they probably do make the difference. Not much power in this car, but it sure feels quick.
-Steve
Old Mar 18, 2002 | 01:18 AM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
I drove to from Indiana to Utah about 2+ years ago with my 79 with 3.70 rear gears and original 4-speed tranny. Just last year, I made the return trip. No problems either direction.
Old Mar 18, 2002 | 06:59 AM
groovyjay's Avatar
groovyjay
Default Re: WOW !!! WHAT A DIFFERENCE........... (sharklover)
That's good news man. I'm thinking about going for 2,73 next summer!!! :p:
Old Mar 18, 2002 | 07:22 AM
SmokedTires's Avatar
SmokedTires
St. Jude Donor '05
A performance rear gear ratio can be the best bang for the buck compared to the engine mods required to match. 3.70's are probably the best compromise ratio. I love my 3.90's and will not be freeway driving some more with the O/D installed this year. Enjoy! :cool:
Old Mar 18, 2002 | 08:02 AM
MARKUS_P's Avatar
MARKUS_P
Default Re: WOW !!! WHAT A DIFFERENCE........... (SmokedTires)
CONSIDERING YOUR SPEED LIMITS I HAVE TO AGREE ;)
On autobahn it´s not a good thing to run such a high gear with a 350.
RICERS EVERYWHERE!!!!!!
Old Mar 18, 2002 | 09:06 AM
Frankenvette's Avatar
Frankenvette
See you at the Poker Run! Oh yea, bring lots of $$$ for all the gas your going to need with those gears. I have 3.55 and burn a tank quite fast.
Regards,
Jim
Old Mar 18, 2002 | 10:16 AM
page62's Avatar
page62
Default Re: WOW !!! WHAT A DIFFERENCE........... (C3Vettesrock)
I've been curious about which diff gears I have in my '79. I turn about 3250-3300 at 70 mph (normal freeway cruising speed around here :reddevil ). I've been told it's probably 3:73. Does that sound right?
Old Mar 18, 2002 | 12:16 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: WOW !!! WHAT A DIFFERENCE........... (page62)
That depends on your tire diameter. check it out here http://www.smokemup.com/utilities/calc/rear_end.cfm
Len
Old Mar 18, 2002 | 01:38 PM
GTR1999's Avatar
GTR1999
I'm interested to hear if you noticed any noise from the Richmond gears? I heard these gear sets are noisey from the factory,but there are a lot of them sold.
Gary
Old Mar 18, 2002 | 02:25 PM
Paul L's Avatar
Paul L
I would say 3.55:1. Those RPMs are what I see also.
Old Mar 18, 2002 | 02:34 PM
ylose's Avatar
ylose
Default Re: WOW !!! WHAT A DIFFERENCE........... (gtr1999)
Gary
I'll bet I won't hear it over my less-noisy gear drive ! :lol:
Old Mar 18, 2002 | 04:38 PM
Aaron76's Avatar
Aaron76
The easiest way to find out for sure is to jack up the rear end and count how many rotations your drive shaft turns for one rotation of the tire.
Example
one rotation of the rear wheel with a 3.55 rear ratio, should trun the driveshaft 3 and 1/2 times approx and 3 3/4 approx for 3.70 and 4 + a bit for 4.11 ratio
any way you get the point.
I hope this helps
Old Mar 18, 2002 | 05:04 PM
verskel's Avatar
verskel
That's great news !
...I plan to do a gear swap in mine sood, too.
3:08 > to > 3:55's or 3:70's :cool:
To WOW !!! WHAT A DIFFERENCE...........
