Its a 77, I had replaced an evap unit & shorted something out. I replaced the guage fuse and they came back to live. I replaced the inst lmp fuse but still no go. I played with the dimmer on the headlamp switch to no avail. What else should I be looking for. I did have the center guage panel out and it all happened when I placed everything back together. I was a dummy for not disconnecting the battery when I did the job.
If you shorted a wire by abarading the insulation it wouldn't have mattered if the battery was connected or not. I happen to have the same problem. My dash lights were working until a few weeks ago and now the fuse blows. I also had the gauge cluster out and I'm figuring that I cut a wire somewhere in the harness with one of the metal brackets under the radio. There are individual wires for each bulb but they all have a common power source somewhere back there. The 77 may power the lights from the circuit board if it has one. Check to make sure you didn't put a screw in without an insulator that may be touching a power trace.
Rick B.
Cut you a piece of wire and strip both ends,attach one end to 12v in the fuse box like one of the BATT taps, take the other end and scratch the INST lamp fuse end and see if the inst lights flicker,if they do then your not getting power to the INST fuse from the green wire coming from the HL switch
OR if you have a 12v test light pull the HL switch out and check both sides of the INST light fuse while rotating the HL switch ****.
You said you replaced the INST light fuse-- did it blow or is it still good ?
I will recheck that fuse in the am, I havn't had a chance to look for a few days. Good info here I will try all & keep you posted.
Pull the center cluster back down and check the big plug going into the printed circuit.Pay close attention to the little thin copper contacts,one is probably folded over.
Roger that Sorry I just had to say that. But yea I will look at that next. I did have that apart but I didn't think that was part of the circuit for the dash lights.
I'll keep you posted.
Thanks again
UPDATE:
I did as you said & bingo . I saw it right away the copper was crossed over another strand and twisted in the corner. I was able to flatten & straighten out the copper strand. I taped the area down flat and that was the fix. dash lights are back.
Thanks for the help
