CAM Question
Old May 16, 2010 | 10:59 PM
Rmorgan&11's Avatar
Rmorgan&11
Default CAM Question
Can you use Solid Roller lifters on a Solid Flat Tappet Cam ???
Old May 16, 2010 | 11:10 PM
Scott Marzahl's Avatar
Scott Marzahl
No, the ramps are designed totally different.
Old May 17, 2010 | 08:50 AM
Rmorgan&11's Avatar
Rmorgan&11
Thanks ,
figured it couldnt be that easy ....lol
Old May 17, 2010 | 09:45 AM
gerry72's Avatar
gerry72
It's not the ramps. Those are inconsequential. It's the taper on the entire lobe. A flat tappet cam has a taper gound into the lobe. This works with the convex ground into the lifter face and forces the lifter to spin on the lobe. A roller cam has no taper since the lifter has a roller riding on the lobe. If you were to use a roller lifter on a flat tappet cam, the roller would make contact only on a tiny part of the lobe and would also experience axial loading of the roller from the taper. The bottom line is still no, though.
To CAM Question
