Pittman Shaft Seal Replacement
Old Mar 18, 2002 | 09:13 AM
John's Shark's Avatar
John's Shark
Default Pittman Shaft Seal Replacement
The pittman shaft seal is leaking on my 71 roadster. The instructions for replacing the seal seem simple enough, but the steering lash adjustment after the shaft and seal are replaced seem a bit too much for me. Is this necessary because you have to loosen the lash adjustment screw to get the shaft out? Is there a simple solution to this? All the stuff about turning the wheel from stop to stop and using a torque wrench on the steering wheel sounds like overkill :confused:
John
Old Mar 18, 2002 | 10:17 AM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Pittman Shaft Seal Replacement (John's Shark)
You need to take a look at Jim Shea's paper on adjusting and rebuilding your steering gear. It is located on this page http://www.corvettefaq.com/susp.asp
There are also a bunch more articles and help links on that page that deal with steering issues.
Old Mar 18, 2002 | 10:20 AM
John's Shark
Default Re: Pittman Shaft Seal Replacement (Smokehouse69)
Thanks! I am checking out the link now.
John
To Pittman Shaft Seal Replacement
