headlight vacuum problem?
Old May 18, 2010 | 04:48 PM
jsholm2's Avatar
jsholm2
Default headlight vacuum problem?
Hey guys,
My right headlamp is slower when opening and closing than the left one. I've read up on the schematics of how they work but I'm unsure as to what the problem could be. Any ideas?
Thanks!
Jonathon
Old May 18, 2010 | 05:45 PM
gbvette62's Avatar
gbvette62
Most likely a bad seal in the right side vacuum actuator. Pull the dust boot back and take a look at the rubber seal (it looks like a witches hat) on the rod. If it's cracked, it's probably leaking vacuum. The seals are about $10, alot cheaper than a new actuator. That's the most likely cause, but it could also be a bad headlight relay valve.
Old May 18, 2010 | 05:52 PM
ssenay72's Avatar
ssenay72
I just did my headlights over, replay both actuators, valves and all the lines. And a few of the springs and bushings. They work awesome now. I had a lazy right side going on. Cured that too. I know its alot of money but i don't regret doing it. Easy job too.
Old May 18, 2010 | 06:34 PM
jordan89's Avatar
jordan89
It's an easy thing to do.
Old May 18, 2010 | 06:44 PM
jae1971's Avatar
jae1971
Nice car jsholm2..
Old May 18, 2010 | 06:51 PM
Cmflorida's Avatar
Cmflorida
Cruising
Most likely a bad seal in the right side vacuum actuator..... That's the most likely cause, but it could also be a bad headlight relay valve.
Same issue with the "lazy eye" a few years back, after putting up with it for months, $20 bucks and 10 minutes, saved me a lot of grief. (And it is very simple to check.)
Old May 18, 2010 | 07:27 PM
stingraydriver74's Avatar
stingraydriver74
I bought one of Zips vacuum refurbishing kits that replaced all the lines, plastic fittings (which get really brittle and break) and the "witches hat" seals on the actuator and it helped and was an easy job. But my problem didn't completely go away til I bought new vacuum relays which are mounted under the front clip in the center just in front of the hood. You can see them when the hood is tilted up and from the bottom of the car. That's where I'd put money on leakage. I think Wilcox has them cheapest but they range from $40-50 a piece.
Brad
BTW its AWESOME to have quick headlights after having slow ones for so long, its a cheap and easy fix, do it!
Old May 18, 2010 | 09:32 PM
jsholm2's Avatar
jsholm2
Thanks guys. I pulled back the boot (which was cracked) but the bottom of the seal seamed to be ok. Can you explain what the easiest way to remove the actuator is, so I can get to the boot and seal? I'm planning on replacing the actuator covers with chome ones, along with the boot and seals.
Old May 18, 2010 | 09:43 PM
ssenay72's Avatar
ssenay72
corvette magazine does a good write up on it, HOWEVER!! do not try to remove it through the front grill !! you'll be there for days!! take the four bolts off (once you take the springs off etc etc) gentle move it towards the center of the car and rest it at the lowest point you can find. Then slowly open the hood as not to scratch it. I did it this way and they came right out from the top without any scratches, no problems. They make chrome covers for them too.
Old May 18, 2010 | 10:10 PM
jsholm2's Avatar
jsholm2
Ssenay72,
Those are great pics. Do the lights need to be in the "closed" position and do you get to the actuator from under the car? Or should I take the headlight encasing off when the lights are in open position to try and get them off? Sorry to keep pestering you. I messed around with it for a little bit today but really haven't had alot of time to figure it out on my own.
Old May 18, 2010 | 10:22 PM
ssenay72's Avatar
ssenay72
I believe the article says " partially open. I think i left them open, cant remember, whichever way had less tension on the springs for removal.
do yourself a favor, if your going to go through taking the actuator or both out, change those rusty springs, bushings, clevis pin and whatever else. It will go back together alot easier. I got it all from zips.
http://www.corvettemagazine.com/tech...both-open.html
Old May 18, 2010 | 11:38 PM
Aussie79's Avatar
Aussie79
here's a quick tip, I have posted this before but here goes again.
Squirt a little CRC in the bottom of the offending sides relay, simply remove the filter (which has probably been long gone anyway) and squirt a little CRC right in there, if the headlight(s) suddenly work better and quicker then replace your relay(s), the seal around the vacuum plunger has dried and shrunk and the oil temporarily gives it a better seal. Works a treat but is not a permanant fix, just a test.
Cheers, Dennis.
Old May 19, 2010 | 11:52 PM
jsholm2's Avatar
jsholm2
Ok, I took a look at the right seal and the actuator is in good working condition. Tomorrow I'm gonna try to diagnose the condition of my relays. I have an idea that that is where my problem is going to be. I'm going to order the spring and hose kit tomorrow along with the actuators (if needed). The hoses seem to be in ok condition, but I figure I might as well do this thing right.
Thanks for all your input. I'll let you know as soon as I get the stuff put back in and get some pics up. Thanks again! Once again this forum is great for Corvette owners!
To headlight vacuum problem?
