Hey, just wondering what the opinions are on the posi differential versus switching to a full locking differential like the Detroit locker. Has anyone done so? Why? And how did you like it? Pro's vs Con's?
I have a 76vette still mostly stock, 4 speed manual, street use predominantly. Just doing some work on the rear end and got offered a locking differential. Can't decide if its a good idea, don't have a lot of experience with differentials. I've heard about noise complaints, but I was wondering how it effects the drive, how bad they really are on wet roads, etc. Thanks!
Reason: Forgot to put, "4 speed manual".
To make this really short; There is no DL application for your differential. The only traction differential available -retrofit or otherwise- is the clutch-type limited slip (Positraction). So whatever it is you're being offered will not fit and is for an application other than a Corvette.
I do have a car with a 9" Ford rear with a 31-spline DL. Most of what you read on the Internet is anecdotal. These people don't have a car with a DL and are just passing old info around. There will be occasions where you do have some clunking, but most of what you read is about 20 years out of date as the design for the holdoff spring changed to eliminate the ratcheting noise.
I can tell you that if this is a daily driver a DL would not be your first choice in a traction differential. But this is moot since you don't even have that option.
I had a Detroit Locker in a C30 with absolutely no problems or noises etc.
They do exactly what the name says, they lock, period.
Shame they are not available for a c3.
We ran a franklin quik change locked. It would be a bit foolish to even consider running one if it is a street car. It will tend to make your rear end slide out when cornering as it will break traction with at least one rear tire. Lockers have a use....but not really on the street....or for the faint of heart
A little Vetteporn....
I broke a ford 9" once and the spiders locked up. It was essentially a spool after that. Had to drive it about 30 miles home. It was an interesting ride to say the least.
