Valve Cover leaks
Old Mar 18, 2002 | 03:14 PM
Koz
Guest
Posts: n/a
Default Valve Cover leaks
My valve cover is leaking. Any suggestions on how to replace it right? Should I use sylicone or Mr. Gasket along with the paper gasket to give it a better seal? Is this a problem area with C3's? Any other suggestions? I've been told not to overtighten the bolts.. Anyone know the specs on this.. I'll be looking it up the next time I'm in the reading room but thought I'd ask while I'm typing... :lol:
Old Mar 18, 2002 | 03:25 PM
bence13_33's Avatar
bence13_33
Default Re: Valve Cover leaks (Koz)
My advise is this. Whenever you replace the gaskets DO NOT use any RTV on the surface. Instead run some RTV around the inside of the gasket. The problem with the cork gaskets is that they absorb oil over time. Running some RTV around the inside of the gasket will help slow down this process.
Lastly when you tighten down your valve covers DON'T torque them down. The torque specs on the valve cover bolts is 90 inch lbs. not ft. lbs :D. I always used to kid my buddy about that. He used to torque those things down and distort the gaskets and valve covers and they'd leak like crazy....and he wondered why :).
If you have any other questions feel free to ask.
Old Mar 18, 2002 | 03:39 PM
79MakoL82's Avatar
79MakoL82
Personally, I used the Moroso rubber on metal frame gaskets. They're more expensive, but I like them. The rubber/cork should work just fine. I put rtv on the valve cover side only to hold the gasket in place while you seat the cover. DO NOT put it on the head side. I believe the torque specs is 45 inch/lbs. Neither here nor there, the best thing to do is just snug them down. Don't over torque.
Old Mar 18, 2002 | 03:57 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Use a rubber or silicon gasket, and don't over tighten it. They just need to snug down so that they are compressed fairly evenly all the way around. They aren't really holding any pressure they are just stopping drips. The Moroso metal/rubber gasket is a pretty good gasket. I've never had much luck with cork gaskets.
Old Mar 18, 2002 | 04:03 PM
page62's Avatar
page62
Default Re: Valve Cover leaks (Smokehouse69)
I used Fel-Pro rubber gaskets (about 10 bucks at O'Reilly's), along with Permatex No.2 sealer. Seems to be a great combo!
Old Mar 18, 2002 | 04:15 PM
Milest's Avatar
Milest
Default Re: Valve Cover leaks (page62)
I use Felpro cork gaskets 7/32" with dots RTV Silicone on the cover to hold the gasket in place. Coat the outer surface with oil and tighten down till just snug.
Old Mar 18, 2002 | 04:39 PM
SteveG75's Avatar
SteveG75
Default Re: Valve Cover leaks (Milest)
Right now I am using cork but I will probably switch to the Earl's rubber/steel gasket when I do the switch to synthetic oil. The Earl's have crush limiters (basically metal tubing) at the holes so you CANNOT overtighten them. I also changed over to the ARP studs which make life much easier (no fiddling with bolts and I just drop the gasket right on).
Old Mar 18, 2002 | 04:50 PM
Koz
Guest
Posts: n/a
Are the Moroso, Fel-pro, Earl's rubber gaskets auto store gaskets or are they specialty gaskets? I don't mind spending a few bucks more if it's going to help. Earl's sound like the best choice since it will help with the want to overtighten.. Where can I find'em?
Old Mar 18, 2002 | 05:01 PM
79MakoL82's Avatar
79MakoL82
I bought the Moroso's at a specialty shop. I don't know about the availability of the others.
Old Mar 18, 2002 | 05:13 PM
rainman69's Avatar
rainman69
I use the cork 7/32" (extra thick) gaskets with no RTV. Just finger tight on the valve cover bolts with the littlest socket wrench.
No leaks. I also use synthetic oil... :smash:
Old Mar 18, 2002 | 05:49 PM
82dukman's Avatar
82dukman
Default Re: Valve Cover leaks (79MakoL82)
I would also recommend sanding down the inside of the lip area where the gasket meets the cover. If ther is any old RTV, it will remove it and make it seal completly.
Old Mar 19, 2002 | 12:00 AM
SteveG75's Avatar
SteveG75
You can get any of the quality gaskets at Jegs or Summit.
http://www.jegs.com http://www.summitracing.com
Old Mar 19, 2002 | 01:19 AM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Valve Cover leaks (rainman69)
I thought you weren't supposed to use synthetic oil with cork gaskets. I too have the cork gaskets, got tired of changing out the rubber ones. Maybe I'll invest in Earl's or some other brand the next time I have to change them (hopefully no time soon).
Old Mar 19, 2002 | 08:33 AM
kleitzel's Avatar
kleitzel
Default Re: Valve Cover leaks (sharklover)
I replaced the valve cover gasket on the passenger side a few months ago. Went to NAPA and bought the Fel-Pro gasket. They recommended not using any RTV or anything else. Just clean up the head surface real good, and don't over tighten. Very easy job!
Old Mar 19, 2002 | 08:43 AM
Pete79L82's Avatar
Pete79L82
If you have stamped steel valve covers make sure they are not distorted by the bolt holes from overtightening. Lay a straight edge along the gasket area and make sure they are flat.
[Modified by Pete79L82, 6:44 AM 3/19/2002]
Old Mar 20, 2002 | 10:47 AM
Koz
Guest
Posts: n/a
Thanks for all the advise.. I think this will be this weekends project..(that is if the new carpets don't come first) I found the local speed shop carries the Fel-pro 7/32 cork for $16 bucks so I'll give them a try. Thanks for all the help! :cheers:
Old Mar 20, 2002 | 03:32 PM
Kingt's Avatar
Kingt
Pete had an excellent point if you are using stamped steel covers. You can fix them with a quick rap from a hammer if they are dimpled. And as others have already pointed out don't overtighten the bolts.
To Valve Cover leaks
