Blower Motor Relay?
May 20, 2010 | 03:53 PM
Blower Motor Relay?
where is the blower motor relay located? and any way to test it?
May 20, 2010 | 04:57 PM
thegazman
What year Vette do you have? On my 79 the relay is above the heater/AC near the firewall.
May 20, 2010 | 05:12 PM
Quote:
Originally Posted by
thegazman
its a 79 also do you mean like behind the radio?
May 20, 2010 | 05:41 PM
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
It's under the hood on top of the firewall in front of the passenger seat. Silver relay staring you in the face.
Jun 1, 2010 | 06:20 PM
Valic
Here's a pic:
http://i181.photobucket.com/albums/x...4/DSCF1684.jpg
You can test with a multimeter and a 12v P/S from a PC. Removing the outer casing will make it easier to see if its functioning.
Jun 1, 2010 | 09:47 PM
If you have high speed only then it is a good bet that you are on track with the relay.
Jun 1, 2010 | 09:55 PM
Make sure you have NOT lost ground in the large Black wire in your picture..
I had a problem where I only had high speed fan and the black wire had heated and broken near the firewall....
Just a guess but the problem could be a bad ground..
Good Luck
1978 ,
1986 ,
72 ,
blower ,
c3 ,
c5 ,
corvette ,
fbody ,
high ,
located ,
location ,
motor ,
relay ,
speed ,
test
