Best method to secure Trans w/Engine removed?
Old May 20, 2010 | 06:38 PM
Rebelrob's Avatar
Rebelrob
Default Best method to secure Trans w/Engine removed?
Looking for some advice, tips on what I can use to secure the Transmission with the engine removed? I do not mean a jack underneath it. That is when you actually remove the engine.
What I am looking to do, is with the engine removed and trans still installed, is to be able to roll the car forward and backwards about 1-2 car lenghts. I have heard using some type of temp cross mount to keep the nose of the trans up right or some how wiring it to the firewall.
I am trying to save space and think outside the box, and just wondering if anybody has done this and what they used. I have very limited space and a trans laying around will not help.
I would rather keep the trans in the car, but if I have to I will remove it.
Thanks,
Old May 20, 2010 | 06:46 PM
sniperdiver37's Avatar
sniperdiver37
Thanks,
I used 1x2 steel tubbing and ran it from the frame rails under the trans. Tapped it into place and it worked fine. if room is an issue maybe rest the in-put shaft on the steel tubbing.
milk crates and chunks of 2x4 just dont cut it
Old May 20, 2010 | 06:48 PM
Bowerss2's Avatar
Bowerss2
honestly i would just remove it, last thing you want is to have it fall and crack the housing. You could make a temp cross member out of a board or something if you are handy.
Old May 20, 2010 | 06:49 PM
TimAT's Avatar
TimAT
Try this: Cut a 2x4 so it'll lay against the firewall on top of the frame, stick a couple of long bolts into the trans and let it rest on that. Notch it or whatever to get it to work.
Old May 20, 2010 | 08:44 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Here's what has worked for me...
1. Cut a 2x4 to fit across the fenders above the bell housing cushioned by a couple of 1/2 inch thick neoprene pads.
2. Put a couple of 1 1/2 inch long 1/4 inch bolts into the upper bolt holes which held the (now removed) torque converter inspection cover, one on each side.
3. Take tension upwards on each bolt to the 2x4 with a pair of small 3/4 inch or 1 inch wide tie down straps. (Small diameter rope works too.) Each strap only needs to support about 50 lb.
4. If you need more tension, simply lift the end of the 2x4 and insert a small 6 x 6 x 1" square board under each end of the 2x4 as required.
This holds the front end of the trans up quite nicely.
Old May 20, 2010 | 08:55 PM
mvette76's Avatar
mvette76
i have under car exhaust so i just cut a piece of rebar to fit across the pipes jack the tranny slide it in to place works perfectly
Old May 20, 2010 | 10:11 PM
Rebelrob's Avatar
Rebelrob
OK, got it. Great ideas. I appreciate it. I am glad I asked yall....
I will provide updates, when I get started on this.
Thanks,
Old May 20, 2010 | 11:00 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
The weight is not that much at all, I put folded towels on the fenders and put a hockey stick across on top of the towels and get some mechanics wire and run it through the top two bolt holes and around the hockey stick. Been doing it this way for 10 years with no problems
Old May 21, 2010 | 07:52 AM
markdtn's Avatar
markdtn
I'm with you. If you are in that deep, just take it out. 2 Mount bolts, speedo cable, kickdown wire, linkage and you are out.
rev-on a 700R4 it's not a kickdown wire, it's a lockup plug, but same difference. Very little work to remove the trans with engine out. You can leave the driveshft in if you want if all you do is move it back and forth a few car lengths.
Old May 21, 2010 | 08:15 AM
...Roger...'s Avatar
...Roger...
One method for auto and one for a 4speed,pretty much the same way I do it, across the fenders with padding ( you can use the lip inside the fender but its not nearly as strong as the tops of the fenders).
My trans holder goes under the trans so it can go on before the trans is separated from the engine, I used to use a jack during the separation process until I tripped over the jack handle one day and did a face plant on the concrete floor.
To Best method to secure Trans w/Engine removed?
