Torque Specs For Entire Rearend
Old May 21, 2010 | 11:52 AM
Fishndude's Avatar
Fishndude
Default Torque Specs For Entire Rearend
Does anyone have a chart or can point me to a chart with all the torque specs for everything on the rearend including u-joints (half shafts and driveshaft), trailing arms, crossmember to rearend bracket, lower shock mount nuts, pinion snubber nut, leafspring bracket nuts, strut rod mounting bracket, adjustable strut rods, etc..
I have all my parts to start assembling my new 4.11 rear end, along with everything else I took apart and fixed/replaced.
Thanks!!
Old May 21, 2010 | 12:33 PM
Clams Canino's Avatar
Clams Canino
The AIM has more... These are just my notes.
DIFERENTIAL ASSEMBLY
(4) Diff. to Crossmember Bolts ........... 55-65
(2) Nose bracket to Carrier bolts........... 45-55 (+ Cotter)
(1) Front snubber to frame................. 55-75
REAR SPRING ASSEMBLY
(4) Rear Spring to Diff bolts ..................... 55-75
(2) Rear Spring hanger bolts............... Cotter Pin
DRIVESHAFTS
(4) Pinion D/S Ubolts ........................ 12-16
(4) Halfshaft to Axle Ubolts................... 14-18
(8) Halfshaft Flange bolts..................... 60-80 (French Locks)
CAMBER STRUTS
(4) Strut Bracket to Diff. Bolts................. 30-40 (was 40-50)
(2) Camber Adjust bolts ........................ 55-75
(2) Shock Mount nuts ........................... 70-80 (+ Cotter)
Diff Plug = 15-20
Old May 21, 2010 | 01:09 PM
Fishndude's Avatar
Fishndude
DRIVESHAFTS
CAMBER STRUTS
Diff Plug = 15-20
Thank you sir, that's more than enough to keep me busy for a while
Do they recommend using any type of sealant or pipe tape on the fill/sight plug for the differential?
Thanks again!!!
Old May 21, 2010 | 01:16 PM
cherrybombc3's Avatar
cherrybombc3
Careful with the spring to diff bolts, the 55-65 can bend the day lights out of the plate. I use 45 ft lbs. with the suspension / car on the ground (loaded). Hopefully others will chime in here as many have destroyed mounting plates using the higher foot lb torque specs.
Old May 21, 2010 | 01:40 PM
Clams Canino
Thanks again!!!
White tefflon tape.
Old May 21, 2010 | 02:35 PM
Fishndude's Avatar
Fishndude
White tefflon tape.
Thank you, I just installed it using teflon tape
The last thing I want is a leak after al this work..
Thats good to know I also have a mono leaf and I dont know if that makes a difference?
I'm not sure why I went with silver on the new 3" half shafts .. The biggest delay so far has been waiting for that darn $3 differential vent to show up..
Old May 24, 2010 | 01:16 PM
cherrybombc3
Im not sure of the torque specs for the mono springs as I never used one?? I like the silver 1/2 shafts. Where did you get them?
Old May 24, 2010 | 02:40 PM
Clams Canino
You get them by sandblasing your old half-shafts and painting them with Rustoleum "Stainless Steel" paint. Then install the new universals.
Old May 24, 2010 | 03:46 PM
Fishndude's Avatar
Fishndude
Ok, the rear end is in the car now.. I still have the exhaust on the car so it was tricky trying to sneak it around everything and then lifting it in place
My new rear end has threaded holes in the side yokes (for the u-joints) as apposed to clearance holes like my original so I had to order different u-joint straps (more delays)..
Old May 27, 2010 | 11:17 PM
cherrybombc3
Haha! The color is not what drew my attention. I thought I noticed balancing weights welded onto each end. I like that they are balanced, most people dont bother as theyre so short, so I inquired where they were aquired. Mine are silver also with a stainless steel spray paint.
Old Feb 17, 2023 | 09:56 PM
AOC Huevo's Avatar
AOC Huevo
1st Gear
Default Differential Front Mount Bushing Torque Value
Attachment 48155298
Do u know the torque value for the bolt that holds the bushing.
Old Feb 18, 2023 | 05:27 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Unfortunately the OP hasn’t been active on the site for ten years. You may be better served by starting a new thread with your question.
To Torque Specs For Entire Rearend
