Wiper Door
Old Mar 18, 2002 | 08:25 PM
rayray's Avatar
rayray
Default Wiper Door
On my '71 before I put my new engine in I changed the heater core, which means I had the dash apart. After I had the engine in I started it and set the valves before hooking up the brake booster to big fitting in the back of carb. It's the bigest fitting being that I had to plug the hole in the Air Gap Intake, because the carb. covers it. Once I plug up the brake booster and started the car, the wiper door opened and won't close. The wipers work. I never had any problem with it before. Any ideals???? :confused:
Old Mar 18, 2002 | 08:31 PM
lbell101's Avatar
lbell101
Default Re: Wiper Door (rayray)
Is the overide switch under the dash open?
Old Mar 18, 2002 | 08:44 PM
rayray's Avatar
rayray
Default Re: Wiper Door (lbell101)
No, that's the first place that I looked.
Old Mar 18, 2002 | 09:30 PM
PRNDL's Avatar
PRNDL
I have an idea, although it is a vague, ill-formed idea. I knocked a hose off of a solenoid under the dash which caused an audible hissing noise (as the hose sucked vacuum) and the wiper door raised. Do you have any audible vacuum leaks? You may have disconnected one of the hoses that sends the control signal. MJ
Old Mar 18, 2002 | 09:49 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Sounds like a hose off somewhere to me, too.
Old Mar 18, 2002 | 11:19 PM
rayray's Avatar
rayray
Default Re: Wiper Door (MNJack)
Where is the solenoid located exactly???? :confused:
Old Mar 18, 2002 | 11:38 PM
jwbert's Avatar
jwbert
It's mounted on the back side of your tach
Old Mar 19, 2002 | 02:28 AM
PRNDL's Avatar
PRNDL
Default Re: Wiper Door (jwbert)
Except mine fell off and was conveniently hanging by the hoses under the steering column. That's how I knocked the hose off - with my foot! I tied it up to keep it away from the pedals. MJ
uh ohhh......ok, take a look :(
http://www.corvetteforum.net/c3/mnjack1/solen1.jpg
[Modified by MNJack, 1:30 AM 3/19/2002]
To Wiper Door
