Replacing Carpet
Old May 23, 2010 | 02:07 PM
mconwayjr's Avatar
mconwayjr
Default Replacing Carpet
I am going to replace the carpet on my 80. I've ordered the carpet and the insulation. I was looking at the old isulation and all the dirt and garbage on the floor board and was wondering if it would be a good idea to apply undercoating to the floor board before installing all the new carpet and insulation?
Has anyone ever thought of / done this? Any benefits? Would the undercoating get gummy due to heat? Not sure if there is any benefit to this. I just thought it may be a nice way to keep the floor board from deteriorating.
Thx.
Marshall
Old May 23, 2010 | 02:14 PM
hugie82's Avatar
hugie82
You better look first. My 82 has a very heavy rubber coating covering the entire floor from the factory.
Old May 23, 2010 | 07:09 PM
LS4 PILOT's Avatar
LS4 PILOT
If I replace the carpet , I replace the heater core. If you know the age and busts , your new carpet will look 10 years old fast. I had this happen.
Old May 23, 2010 | 10:40 PM
Bee Jay's Avatar
Bee Jay
Fatmat Baby. Then a layer of felt if your crazy like me. Then the carpet.
Bee Jay
Old May 24, 2010 | 01:25 AM
martinsw's Avatar
martinsw
I put down home made lizard skin (paint mixed with micro spheres) on the bare metal, then reflectix, then carpet underlay and carpet. The micro spheres helps with heat, and maybe some with sound, only took about $10 of micro spheres. Reflectix helps mainly with heat. Dynamat or fatmat like bee jay used is also a good way to go - just more expensive than reflectix.
Old May 24, 2010 | 10:58 AM
wan2run's Avatar
wan2run
Many put rust preventative paint (i.e. POR-15, Rustbullet) on the metal floorboards when replacing the carpet. As mentioned, now would be the time to put sound deadening and heat reflecting products in if you desire. Also as mentioned, it's a good idea to replace the heater core - don't want coolant ruining your new carpet.
Old May 24, 2010 | 11:22 AM
MakoShark72's Avatar
MakoShark72
Dynamat Extreme covered by Reflectix covered by carpet... Quiet (OK, not as loud!) and cool!!
Old May 24, 2010 | 11:34 AM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Undercoating??? what about bed liner for trucks? i know it wont become soft... just a thought.....
To Replacing Carpet
