Is this leaf spring in correctly?
Not sure what year they moved away from the steel springs on the 80's. I thought most had switched to the composite by then. Or maybe the 4 speeds had steel springs. Here is a pic of my stock spring, my space looks a bit different than yours, yours is obviously new and better design. I got 8 inch spring bolts and I got about a 2 finger width gap between the tire and the fender lip. I have them as low as they will go. I would like another good inch lower, so I will probably have to go with 10 inch bolts and cut the remaining amount down. As mentioned above if you roll that car back about 30 ft or so, the IRS should settle.
[IMG]
[/IMG]The Best of Corvette for Corvette Enthusiasts
The nuts are threaded just in enough for one thread or so coming through, so the spring is extended virtually the entire length of the bolt? Is this correct to get the lowest ride height?
Something just ain't right with these springs and the constant ride height issues. It seems logical to me that the new spring should give a factory ride height with a factory bolt length (6 3/4") and the allow real lowering by using longer bolts. Look for a future thread on this topic.
I also have a side anomaly that my tight fitting exhuast system is touching the spring..
so now I have to get the exhaust modified to clear the spring, which means driving it across town to the pipe master uncapped.
and have to pass right by the police dept to get there...good thing the cops in this town have a little sense of humor.
Note to Grumpy 427;..check your exhaust clearance..when I spoke to Van Steel today they reminded me about every other word to keep the exhaust well away from the spring.
Anyway this better be worth it. My gut told me to go with a 7 leaf performance steel spring which would have cost $125.00 and would bolt right in without all these issues. Every time my mind overrides my gut it turns out bad!
-W
Anyway, my spring has an equal amount of composite spacers both above and below the spring. They were taped to it that way and so I left 'em that way. I also have the steel heat shield that goes between the exhaust and spring perch, uses two 10mm coarse threaded screws to mount to the strut brace.
I don't know I have seen several similar complaints about the VBP piece as well...I have also seen threads and pics were the VBP unit had snapped...maybe installation errors? but who knows there have certainly been some of those.....well I must decide today whether to keep this spring or send it back and go to plan B...
My gut feeling tells me a large part of these "high sitting" springs were dug out of a dumpster on there way to the landfill many years ago and have found their way back into the market.
No manufacture in their right mind would continue to produce a spring that is returned to them as defective.
( Imagine if you worked at the plant producing these springs and you see a dumpster full of newly made springs on their way to the dump, your pickup truck could easily hold a hundred or so, sell them for 50 bucks a piece brings in an easy $5000. How many pickup trucks were in that lot ?
Thanks, Dave
)I mean .. here's an ad from 1974 ... lots o gap
And from '69 ... gap abounds
