1968 coil wire question
Old May 24, 2010 | 06:19 PM
Grinchia's Avatar
Grinchia
Default 1968 coil wire question
Both wiring schematics I have for 1968 show two wires connecting to the positive side of the coil: a yellow wire from the starter solenoid, and a white-red-black wire that is supposed to originate from the passenger side firewall connector to the back of the fusebox. The yellow wire is straightforward enough, but I cannot find the second wire anywhere. Am I chasing a ghost here?
Old May 24, 2010 | 06:31 PM
...Roger...'s Avatar
...Roger...
The second wire goes to the bulkhead connector then to the ign switch.
Old May 24, 2010 | 07:08 PM
Grinchia's Avatar
Grinchia
But I'm not finding such a wire on the bulkhead connector...is it in fact white/red/black, or some other color?
Old May 24, 2010 | 07:11 PM
...Roger...
On the 68 I believe its a tan wire with red and blue tracers.
Old May 24, 2010 | 07:25 PM
Grinchia's Avatar
Grinchia
Thank you, I will go and look. Funny that both wiring schematics I have are specifically labeled 1968, but neither mentions a TAN wire
Old May 24, 2010 | 07:45 PM
...Roger...
I have a NOS 69 harness that the yellow (one going to starter) is tan and the other wire which is the resistor wire going to the bulkhead is black and says "resistance do not cut" in red and then again in white. You just never know !
Old May 24, 2010 | 07:47 PM
...Roger...
Your wire should be in the passenger half of the bulkhead at around 6 oclock view from front of car just below the orange blower motor wire.
Old May 24, 2010 | 08:14 PM
Grinchia's Avatar
Grinchia
Found it! It is indeed a tan colored resistor wire (some kind of fiber insulation over the tan/yellow plastic insulation inside). NOW I'm all set. Thank you very much for your speedy assistance
To 1968 coil wire question
