Interior Restoration Questions
Old Mar 18, 2002 | 11:19 PM
Chris Butchart's Avatar
Chris Butchart
Default Interior Restoration Questions
I am planning to replace the carpeting, seats, shifter console trim and door panels in my 1980.
Any specific "danger areas" to watch out for?
In other words is this too much for a novice to handle? :D
Old Mar 18, 2002 | 11:21 PM
82dukman's Avatar
82dukman
Default Re: Interior Restoration Questions (Chris Butchart)
Not at all. Just take your time and go slow and it will work out. Keep track of where all of the screws are located.. If you are missing some, I would recommend a new interior screw kit too. If you have an AIM it greatly helps.
And welcome to the forum
[Modified by 82dukman, 10:21 PM 3/18/2002]
Old Mar 18, 2002 | 11:45 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
This was one of the first projects I attempted with my Vette. Check out my website for photos of the redone interior.
It's not that hard. As mentioned, spring for a new screw set. They cost less than $30, and are worth every penny. Also, be careful when removing the upper dash pad. It's easily cracked. Mine was fractured in several spots. I used Plumber's Goop to repair the cracks. This did an admirable job repairing the plastic frame, but if I were to do it over, I'd buy that two part epoxy. It's a lot stronger. Also, be careful with the hard plastic parts (i.e. gauge panel). The screw receptacles on the back are pretty fragile.
Good luck. E-mail me if you have questions.
Old Mar 19, 2002 | 12:09 AM
bl75vette's Avatar
bl75vette
Hi Chris
As you can see below, I'm in the same process. Tonight I just removed the dash pad and speedo/tack panel. I am replacing the printed circuit board on the tach. Then it time to lay the insulation and carpet. I just finished replacing the leather seat covers. Came out great! Door panels were standard because the previous owner was too cheap to put the right deluxe ones in. I bought the components for from RIKS to make them deluxe. Like the others said, take your time and do not glue the carpet down. :chevy
Old Mar 19, 2002 | 12:17 AM
Pete79L82's Avatar
Pete79L82
I would also recomend putting down a heat barrier while you have your carpet out. You will be glad you did.
Old Mar 19, 2002 | 12:25 AM
Carl in LA's Avatar
Carl in LA
Default Re: Interior Restoration Questions (Pete79L82)
My tip is to go ahead and use the vinyl spray paint on all the interior panels... The paint I got from Ecklers was most easy to use... way easier to use verses regular enamal spray paint. Really made the interior look outstanding... And be sure to paint the steering colum while your at it. Another tip... when working on the gages, replace benzel lenses (the clear plastic part) on all places including the headlamps and door ajar indicator lights.
To Interior Restoration Questions
