Transistorized Ignition wire connections?
Old May 26, 2010 | 07:07 PM
JohnRR's Avatar
JohnRR
Default Transistorized Ignition wire connections?
Hi Y'all,
I have a stock '73 BB. Can someone please tell me where the two wires(red & black) go from the bottom of the transistorized ignition distributor?
Thanks a lot!
John
Old May 26, 2010 | 07:42 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I have a factory diagram for the 1969-1971 on the web site.. it should help you.
http://willcoxcorvette.com/repairand...lp.php?hID=265
Willcox
Old May 26, 2010 | 08:02 PM
JohnRR's Avatar
JohnRR
Well, now I know that I really don't have a factory TI setup. What I have is a module mounted where the points normally would be. It has a label on the side that says "Ingitor LS". The rotating 8-lobe cam on the distributor looks like a standard points type. Perhaps this is actually an aftermarket points replacement device?
There are only 2-wires coming out of the distributor; red & black. Should I connect the red to the + side of the coil and the black to the - side of the coil/
John
Old May 26, 2010 | 10:23 PM
Solid LT1's Avatar
Solid LT1
You have a Pertronix ignitor, both wires go to the coil red=positive (+) black=negative (-). I would run factory resistance wire with standard Ignitor ignition (9-10VDC while running.)
Old May 26, 2010 | 11:29 PM
JohnRR's Avatar
JohnRR
Hey Solid,
Thanks for the info. I just replaced the entire wiring harness with a set from Lectric Limited. There is a special yellow, nylon covered wire that goes to the + side of the coil that might be the resistor that you speak of. I'll check it out once I get it running again.
Thanks for the quick reply!
John
To Transistorized Ignition wire connections?
