I have a '73 with the fuel pump return and the vapor canister system removed. The lines are plugged. The AIM has a page that shows the fuel system schematic including tank, vapor canister, fuel lines, etc.
If you don't have the AIM I can scan the page but I can't post attachments.
BTW...if you disconnect the return system you will need to replace the unvented gas cap with a vented gas cap.
Reason: added BTW...
The return line is not a vent , but its hard to wrong with a vented cap.
