radiator problem
Old May 29, 2010 | 01:30 PM
ron dokken's Avatar
ron dokken
Default radiator problem
I bought a Replacement alunium radiator for my 1981 fit was ok but lower hose connection interfered with sway bar anyone else had thi problem.looks like I will have to build about a 3/4 inch spacer for sway bar mounts? ron
Old May 29, 2010 | 05:55 PM
SIXFOOTER's Avatar
SIXFOOTER
some of them are awful close. best solution might be a spacer. Make sure the mount pads for the radiator are in good shape
Old May 30, 2010 | 11:47 AM
ron dokken's Avatar
ron dokken
Thank's new pads used a 3/4 spacer seemed to work fine.Ron
Old May 30, 2010 | 12:06 PM
Grumpy 427's Avatar
Grumpy 427
What brand and part number of Radiator did you use, also what were your cooling issues and were they solved with the new rad. I am running a 340 Hp 350 SBC with gm waterpump, 180 stat and factory 3 core rad. I had the rad shop remove the tanks and rod the cores to open them up. GM allways made a decent 3 core rad, i see the only real problem with the vette is the fact the rad is layed back on an angle reducing real airflow through it. I have not run the car yet but was hoping to be free and clear of cooling issues.
Old May 30, 2010 | 07:58 PM
Richard Cooper's Avatar
Richard Cooper
Ron,
I had the same exact problem with my 81. I just used enough spacers to clear the snout. I did this on both sides of the sway bar to keep things even. I did this 4 years ago and have had no problems at all.
Old May 31, 2010 | 12:45 PM
ron dokken's Avatar
ron dokken
thamk,s came to the same conclusion.ron
Old Jun 1, 2010 | 09:20 AM
1980 blue L48's Avatar
1980 blue L48
Sounds like my $170 radiator, 3/8 spacers worked on my 80. I also had to trim the drain, (plastic and was on the drivers side) I wish I would have sent it back and got a Dewitts Quality piece. Mine was a copper/ brass unit that has not cooled as good as my original.
Old Jun 1, 2010 | 06:33 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Originally Posted by Grumpy 427
What brand and part number of Radiator did you use?
That might help others in selecting their next radiator.
C3 radiators are not easy to build correctly and we've found the only way to located the tubes is with a fixture, so each one is the same.
Many people think our 69-72 sb tube has been damaged, until they find out the stock radiator has the dent too. That's for stabilizer clearance.
To radiator problem
