Fram Oil Filter????????????
Old May 30, 2010 | 05:08 AM
78 C3 Light Corvette Blue's Avatar
Acct suspended by request 19 April 2011
Default Fram Oil Filter????????????
Why is everyone against Fram???
Been around for years. Used a bunch of them and never a problem.?????????
Old May 30, 2010 | 05:47 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Because in most independent tests over the years they fared very poorly on filtering proficiency. From what I read, they have improved significantly in recent years. Still hard to beat anything made by Wix.
Old May 30, 2010 | 08:51 AM
jr105's Avatar
jr105
If you want to compare filters I found this site
http://minimopar.knizefamily.net/oil...reference.html
Basically the Fram has relatively low filter surface area and the anti-drainback valve doesn't work well. This allows the oil to drain back into the oil pan on vehicles that don't mount the filter vertically like my 350. That results in a momentary dry start until the filter fills again.
Old May 30, 2010 | 10:10 AM
oleyellar72's Avatar
oleyellar72
Default Oil Filter
Thank you for your investagation, I always thought Fram was one of the best!! I have a 1972 350 sbc new rebuild with a fram on it I will be changing to a baldwin I think. AGAIN THANK YOU FOR THE INFO.
Old May 30, 2010 | 10:26 AM
Rmorgan&11's Avatar
Rmorgan&11
Wix is what most run in the industrial side, Baldwin is or used to be made by Wix.
another test >
http://www.corolland.com/oil-filters.html
Old May 30, 2010 | 12:53 PM
Goody's Avatar
Goody
I run Mobil1 filters since they are available locally.
Old May 30, 2010 | 01:10 PM
Corey_68's Avatar
Corey_68
Because Fram is crap and have known to cause engine failure when the filters come apart internally with their shoddy quality control.
Old May 30, 2010 | 03:08 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
Cut one open sometime....
Wix/Napa is what I use now.
Old May 30, 2010 | 04:42 PM
Paul L's Avatar
Paul L
Agreed. I use NAPA/Gold which is a Wix product. The 1061 is an equivalent of the old Delco PF-35 and the later PF-1218. No problems.
Old May 30, 2010 | 04:45 PM
stpman's Avatar
stpman
I use CarQuest brand filters in my DD's made by Wix
Old May 30, 2010 | 05:59 PM
BKarol's Avatar
BKarol
OT held a discussion last month.
http://forums.corvetteforum.com/off-...re-is-why.html
notice post #21
Old May 30, 2010 | 09:48 PM
jordan89's Avatar
jordan89
notice post #21
That was a good one.
I use K&N oil filters on both the Vette and the Z28.
Old Jun 2, 2010 | 09:12 PM
VCuomo's Avatar
VCuomo
I use K&N, NAPA, Purolator PureOne, or Wix for my vehicles. Amsoil also has a filter that is well regarded.
Old Jun 3, 2010 | 12:32 AM
Bugman Jeff's Avatar
Bugman Jeff
I only have one car I'll use a Fram filter on, my '55 Plymouth(and mostly because it's the only one available locally). The oil filter was an option, and it's a bypass type system. That means it filters some of the oil, some of the time Everything else gets a quality filter
Old Jun 3, 2010 | 01:47 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
I've used AC Delco & Purolator filters on my cars with no problems. Never really messed with Fram filters (except back in the '80's..still got two old PH8A's from back then in my garage).
Old Jun 3, 2010 | 07:17 AM
markdtn's Avatar
markdtn
This is an interesting article. I use either Wix or Delco on mine.
Old Jun 3, 2010 | 07:52 AM
L88Plus's Avatar
L88Plus
Most folks think Fram is great simply because they advertise out the wazoo.
To Fram Oil Filter????????????
Old Jun 3, 2010 | 11:20 AM
ClockworkOrange's Avatar
ClockworkOrange
I have never used anything but Fram filters on any of my cars in 38 years of driving. So I am going to say that the filter surface area must be sufficient to do the job required and that the anti drainback weakness cannot be that much of a weakness.
Old Jun 3, 2010 | 11:53 AM
SH-60B's Avatar
SH-60B
X2. I never had a problem with any oil filter, Fram or otherwise.
Old Jun 3, 2010 | 01:37 PM
early shark's Avatar
early shark
I use the WIX 51061 filters.
