Extensive BB water temp testing.......(Mr. Dewitt, please step in..)
One thing I've learned is that there is usually little value in *cleaning/rodding* an old radiator. Yes it gets the tubes flowing, but the real issue is the *insulation* that has built up inside the tubes like a thin coating. It's very common and coolants react to heat in various ways...but usually they create a coating at hot spots that only makes things worse. I see it all the time in the diesel world. Recoring a stock radiator gets good heat transfer again through the tubes..just as the new Dewitt's is going to do.
JIM
What method do you use to limit a vacuum advance?
Example, I get about 16-17* out of my vac advance at 1500-3000 ish.... I would to limit that vac advance to about 7-8* max....or cut it in half per say.....without welding on the track, can I just use a small nut/bolt combo screwed in the track to stop the vac adv arm on the pick up?
http://cranecams.com/pdf/254g.pdf
Not sure if that will work with an MSD 8572 or not though..... I will pop the cap off this weekend and take a looky....for some reason I thought it was just a track on the VA and the arm from the diaphragm slid in it pulling on the p/u coil....I figured I could rig something up...maybe not.
Changes made:
Everything the same as last test except I set the locked timing at 32*, I made a vacuum advance limiting plate and limited my total timing to 36.5* at 3000 rpms....so basically 4.5* worth of vacuum.
Test:
Not quite as hot as last week's test...about 2-3* cooler ambient temps. I drove the exact same 30 mile test route keeping the rpms around 2950-3000rpms.... Car ran 190-191* the entire time....I mean the gauge was stuck at 191* max.....exiting the freeway and idling in town it went to 195* but I am betting it would have started to cool down some after the initial heat soak from the highway drive cooled down..
Deductions:
The car definetly likes the extra 4-5* of timing at part throttle, makes it snappier around town, runs a little smoother down low and knocked off an average of 4-5* in water temp....(depending on ambient air). No noticeable pinging around town with the AC on and vac adv hooked up, straight 93 pump gas.
So the last thing I am going to do to reduce temps is installed the Dewitts AL radiator....Hopefully it will knock another 10* off of this thing to give me some room for when its REALLY hot.....We average about 97* here in the summer and often times break 101-102* so....I need a little more cooling.... When I put the new radiator in, I am going to run 2- gallons of Prestone anti freeze, 3 gals of distilled water and try to put the thermostat back in and see what it does.....If it runs hotter, I will put the thermostat back out....also may add another water wetter but only if needed as that makes a nasty mess of the coolant.
I have this gauge right here tucked up behind my console...
The sender is in the intake. I still have the factory gauge hooked up with the sender in the driverside head. They are only 2* apart at 210*....verified with IR gun also.
Hey what the heck were louvers invented for in the first place?
Nice effort ajrothm,
cardo0
cardo0
That’s why I posted this earlier.
A lot of BB guys have solved cooling issues by venting their hoods.
Check these pics
http://forums.corvetteforum.com/1574006192-post6.html
Old VW engines had the flaps too.
Check these pics
cardo0
Living in Houston I was at my wits end with this **** to be frank.
I had similiar issues. New shroud, DeWitts Radiator etc..... much of the same testing. To be honest I never resolved the issue!
Now the motor is being rebuilt; that might help? I figure I will be back at square one. I want to remove the Stewart Warner high flow pump and go back stock. I did not see any improvement at all; I know it "should" work physics right, but it does not seem to help at all.
I was so frustrated that I wanted to sell the car; seriously. I could not drive for several months of the year in Texas.
As a back up instead of selling the car that I like I have bought a back up old car .... an old air cooled Porsche ... maybe not real smart in Houston
Changes made:
Installed Dewitts radiator, all new seals(again), reinstalled my 160* thermostat, no water wetter..... Just 2 gals Prestone AF and 4 gals or so of distilled water. Timing still at 32* locked and 36.5* with vac advance.
Test:
Finished the radiator install sooner then I thought, I was very careful to seal up every gap/hole I could find between the shroud and radiator. Left my house with it at 160* and got to the freeway with it at 170*, AC ON... Got on the freeway, ran it up to 3000rpms and it started COOLING DOWN...
Got down to 165*....stayed at 165* for 15 miles or so running 70+.....I sped up to 80mph and it stayed at 165*.....I slowed down to 60 mph, punched it a couple times...168-170*..... Running 60-65 mph it stayed around 168-170*.....speed back up to 70 mph and it stayed at 165-167*. Ran the 15 miles back home, it held this temp, exit the freeway and running through town at 30-35mph it was around 170-175*.... Stopped at the house, left it idling in the driveway with the AC on for about 15-20 mins and it was at 195* but it seemed to be stable there.....AC blowing 45*. I didn't drive it again to see if it cooled down at speed but I am sure it would. Deductions:
NOW its not as hot as my usual testing....Normally it is 92* when I test so its 4* cooler out now but the difference in highway temps is atleast 20* drop with the Dewitts radiator. I haven't really tested it much in town yet either but I assume its gonna run 195* or less in town with the AC, probably in the 180s if I am moving at all...
So at this point, I am done with it.....Unless for some reason it starts to get really hot in town, I am gonna call it good. We will see when our temps go up another 10-12* ambient though....for now, I am happy with it.... 650hp BB with AC running <170*.....can't beat that with a stick....
Fingers crossed....
better cooling , less prone to pinging , 70lbs less. i think you need all of these
i'm astonished by the cleaness of your motor and engine bay...never been able to have mine like your
Just food for thought. I may be ordering one of those aluminum radiators once I can save up $550, and that's no easy task.
