EGR Valve
Thanks,
Dan
For example My 78 L82 came with just that type of EGR. Now some cars were equipped with a ported EGR which indeed should hold vaccuum. It is necessary to know exactly which type you are dealing with before the question can be answered.
A search on NAPA auto parts will give you some idea which cars came with what, if you have the original part number you can cross reference it as at least the Echlin EGR valves seem to all provide the OEM part number matches.
EGR Valve Type : Int. Pos. Back-Pressure
Material Safety Data Sheet There is no MSDS for this item
Application Information: 1978 Chevrolet Corvette
Comments: w/ Manual Transmission;w/ High Performance Engine;w/ OEM # 17056495
Per Car Qty: 1
To test this valve, bring the engine up to 2,000 rpms to create back pressure, then apply vacuum. EGR should open and cause a 100 rpm drop or more. Exhaust leaks or a modified exhaust system can create havoc here.
http://www.asashop.org/autoinc/dec97/egr.htm
Having a '78 L-82 like you, it appears that the correct EGR is the back pressure type vs port vacuum, am curious on your take on the EGR impact of headers and a true dual with x-pipe exhaust system?
Specifically in relation to my thread I'm stumped: Timing, Vacuum & Secondaries
The above linked article states:
Can a port type EGR be used as a replacement for a back pressure type to overcome changes made to the exhaust system.
It certainly can be tried
Am thinking that with the headers and dual exhaust that I'm not generating enough back pressure to fully activate the EGR which is adding to my cylinder temps and detonation/pinging.
