It is my understanding that while you 'can' drill and tap these heads for the accessory bolt holes, it is NOT ADVISED, since the heads likely don't have the cast reinforcements at these loccations, which are present in heads originally cast with the accessory bolt holes.
Kind of like you can drill out and tap the Vortec heads for the old intake manifold, but this method is not recommended, and probably not very reliable.
461's are early 60's 327 heads (AKA fuelie heads) You should be able to sell them very easy for a good price and then buy something better suite for your needs. :blueangel:
