Light actuator problems... TRIED EVERYTHING.
here's what I got.....
My headlights are coming up and down rather slowly.. Especially the passenger side. I replaced both relay valves, all exterior vacuum lines, filters, and t's on the exterior. I replaced the seal in the passenger actuator and since the problem is especially bad in that side, I didn't see any reason to take out the other. The seal was in good condition on that side anyways but since I already had it out, I replaced the seal. I plugged both holes on that actuator and the rod wouldn't move with the holes plugged. (I assume this means the actuator is in good shape). I replaced all springs with stainless ones as recommended. The only thing I haven't done is replace the lines running inside the car since the dash is so hard to remove. I'm running out of ideas to try.
Oh, and by the way. Now I have a headlamp warning light coming on in my center cluster. Do you guys have any idea on what could possibly be wrong? I've double checked and all the lines are installed properly. The lamps are coming up better than what they were but still sub par.
Thanks!
Jonathon
Now apply vacuum to the front nipple (green) if the vacuum drops then the seal must be replaced.
The warning light on the dash is electrical and goes out if the switch is good and positioned correctly.
Here's a picture of what the switch actually looks like.
Jonathon
You don't have to buy a vacuum tester unless you want to, you can borrow one from the auto parts store.
I forgot to mention when you test the front nipple have the head lights UP.
Here's a how to: the text is good but the diagram in incorrect at the head light and pull down switch. www.corvette-101.com/vacuum.htm
Hope that helps.
