Help select headers for GMPP ZZ383
Old Jun 1, 2010 | 06:11 PM
livelotus's Avatar
livelotus
Default Help select headers for GMPP ZZ383
I'm working on selecting the headers for my ZZ383. The original long hookers that came with my vette are 1 1/2" dia tubes to a 3" collector.
My new 383 with the GMPP AL heads use a 1 3/4" D tubes. I really don't think the 1 1/2 hookers will work correctly. So what are my choices?
I have a 4sp car with the Z bar mechanism.
H
Old Jun 1, 2010 | 06:53 PM
ELDO GUY's Avatar
ELDO GUY
well, I used my hooker side mounts on my zz4 and they seem to work . I used the D gaskets on the engine side and the regular gaskets on header side. I matched them up and cut out any thing that didnt line . I also ground a few spots inside the headers that did line up so good . Those sidmounts were going on no matter What !
Old Jun 1, 2010 | 06:56 PM
ZZ71S's Avatar
ZZ71S
Headman makes a \D port header
Old Jun 1, 2010 | 07:09 PM
SteveG75's Avatar
SteveG75
Hooker sidepipes are 1-7/8" primary. Most small blocks are 1-5/8" primary. Totally different beast.
The OP would be fine with a 1-3/4" primary like the Hooker Super Comps.
Old Jun 2, 2010 | 12:50 PM
livelotus's Avatar
livelotus
Steve,
I looked at summit for the suggested Hookers, but they listed quite a few. By chance, would you know which ones? I want to make sure that I don't need to tweak the drivers side to allow for the z-bar.
H
Old Jun 2, 2010 | 10:03 PM
maroon67's Avatar
maroon67
Hooker #2134 are 1 3/4" long tube, for under the car exhaust.
Call Jet Hot for Corvette Forum discount.
Good Luck
Old Jun 2, 2010 | 10:30 PM
SteveG75's Avatar
SteveG75
Originally Posted by livelotus
Steve,
H
All the Hooker sidepipe headers are the same design. It is just the finish/material that is different. I would recommend going stainless or if you want ceramic, buy direct from Jet Hot.
Old Jun 3, 2010 | 09:03 AM
livelotus's Avatar
livelotus
Thanks All,
How do I go about to get the forum discount fron Jet-Hot?
Howard
Old Jun 3, 2010 | 08:47 PM
maroon67's Avatar
maroon67
Thanks All,
Howard
When you call them just tell them you are a forum member.
You may need to include your forum handle.
Larry
Old Jun 3, 2010 | 10:03 PM
livelotus's Avatar
livelotus
Called Jet-Hot and got the price on the headers with the discount.
BIG QUESTION: what would the difference in performance be between 1-3/4 versus 1-5/8 primaries? Just asking because the 1 5/8 are alot cheaper....
H
To Help select headers for GMPP ZZ383
