trans cooling lines removal from front tips?
Old Jun 6, 2010 | 11:49 PM
glarior's Avatar
glarior
Default trans cooling lines removal from front tips?
Have any tips to gain access to the transmission cooling lines on the side of the radiator? This is for an 80 vette... I just can't get my hand in there and really don't want to remove the entire radaitor setup....
Old Jun 7, 2010 | 07:36 AM
JimT's Avatar
JimT
Not sure of your setup (cooling line tubes in front or rear of radiator), but I have accessed this same area by removing the fan/fan clutch, then if necessary, the fan shroud (may have to remove upper radiator hose also). Good luck.
Old Jun 7, 2010 | 09:18 AM
jimvette999's Avatar
jimvette999
A small pipe wrench (5" long) will bite and let you remove the fittings. Only solution I know of without doing it right and removing parts.
Old Jun 7, 2010 | 09:31 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
try coming in from the bottom...
Old Jun 7, 2010 | 10:52 AM
glarior's Avatar
glarior
My connections are on the front of the radiator.
Might have to try...
Thats the way I was trying. I can get the first one but the second one I don't think I can get to.
To trans cooling lines removal from front tips?
