installing new carpet
Old Mar 20, 2002 | 11:35 AM
stroked 76's Avatar
stroked 76
Default installing new carpet
i just received my new full carpet for my 76 and am going to install it on saturday,just wondering if there were any tips or things i should know before starting.I have already removed old carpet and threw in the garbage,looks easy but i am not sure about the rear compartments and putting new carpet on them thanks in advance
Old Mar 20, 2002 | 11:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Default Re: installing new carpet (stroked 76)
Get the old stuff out of the trash!! It helps to use the old carpet as a template for hole cutting and trimming on the new stuff.
Old Mar 20, 2002 | 11:45 AM
Alwyn678's Avatar
Alwyn678
Default Re: installing new carpet (Easy Mike)
What kind of backing are you using,....Also did you get the 3m Spray Adhesive to hold every thing down....?? Just take your time it is simple to do
1LE's Avatar
1LE
Well I used my old carpet as a pattern to cut my heat barrier stuff .
To installing new carpet
