Intermittent Bright Lights Indicator
Old Jun 7, 2010 | 08:22 PM
Bernie2001's Avatar
Bernie2001
Default Intermittent Bright Lights Indicator
I just had my 75 painted and am now experiencing a few oddities.
1) The head light warning light is on - found broken switch on left module. replaced it and all is good.
2) Blue Bright light indicator in dash does not operate reliably. Sometimes while driving at night, light will go off, sometimes it comes back on.....not reliable. It's awkward while driving to not be sure which set of lamps is on. lamps all operate as normal, just indicator lamp problem.
Old Jun 7, 2010 | 08:59 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Aren't these old cars fun ??? My right turn signal lights up for no reason when it is not even on
Old Jun 7, 2010 | 09:31 PM
...Roger...'s Avatar
...Roger...
Thats usually a bad ground at the 3 wire connector going to the turn signal.
Old Jun 7, 2010 | 09:33 PM
...Roger...
Probably a bad bulb or bad connection at the bulb.
To Intermittent Bright Lights Indicator
