1. Applying ionized color-powder to metal surfaces and bake it to a hard coat finish.
2. Bare metal, ionize color powder, apply, cure in oven for ~ 20 min at 300* F.
3. ~ twice the cost of paint, but 3 times thicker and tougher
4. tough hard coat, outperforms paint with ease. Resistant to lots of chemicals.
I like the powder coating A lot. Just don't use any carb clearner around it. The carb cleaner will stick the dirt to it for good. Gas and grease wipes right off. I have yellow valve covers and that was a mistake. I had my stock intake manifold done In gloss black and looks great. :cool:
Powder coat is excellent stuff & I'd highly recommend it. The frame on my m/cycle was powder coated many years ago & the lower tubes that get constantly hit by stones etc look as good as the day they were done.
The orange peel effect can be removed by using T-cut, or a similar rubbing compound, to give a high gloss finish (takes a lot of effort though!).
Powder coating quality can vary from place to place. The people who did all the bikes I built put it on really thick, which filled any surface imperfections. The people I've had to use for my Vette parts put it on thinly (probably trying to maximise their profits :mad ) & while it is just as tough, it doesn't have the smooth high gloss finish :cry
Removing powder coat can be a real nightmare & I've just discovered that cellulose thinners soften the surface. It sets hard again but then has a dull finish.
Go for it! Try a couple of test pieces 1st (unless you do it yourself) as the finish seems to vary between painters.
:cheers:
Thick application isn't always desired. When the powdercoated part flexes (like a spring) it's better to have a thinner coat. Too thick will make it brottle and it WILL chip!
The gun was on sale at Eastwood for 100$ or so (someone here posted it back then, I think it was monty!)
You should also order the hi-po deflector. The stock one works too slow. The only advantage of the higher $ guns are that you can hold more powder and you won't have a seperate voltage supply w/ seperate ****. If you practice a little you'll be so fast at switching bottles the smaller capacity isn't a problem.
The way to get the best results is by pre heating your object. This will also minimize orange peel (wich is partly caused by the grains not fully flowing all the way). Pre heating also minimizes the chance of knocking off powder and it will evaporate all solvents you used to degrease. If it's VERY rough after curing it hasn't cured long enough.
Oh and it's NOT recommended to recycle the powder. However, powder isn't cheap so if you have parts that just need coating and don't need to be super nice you can recycle it if it's NOT contaminated.
