Rear Leaf Spring Help
Old Jun 10, 2010 | 09:32 AM
Fishndude's Avatar
Fishndude
Default Rear Leaf Spring Help
I have a few questions I could use some help with.
1. Are the leaf springs in a 78-82 wider than the 68-77 and are the 4 spring mounting bolts designed to sandwich the leaf spring for added support? I just replaced the 3.08 in my 68 with a 4.11 that came out of a newer model and the spring mounting bolts are 7/16 and not 1/2 like the original. The original, with the 1/2" bolts, were snug against my leaf on both sides (sandwiched the leaf) but now with the smaller 7/16 bolts, there is a nice gap between the bolts and the spring, does this gap matter? Below is a picture and the bolts have not been tightened yet..
2. Also, my new leaf spring bushing kit only has one bushing cup, which side the does the cup go, the bottom of the leaf spring or in the trailing arm pocket? My original had cups on both ends..
3. When installing my new trailing arms, should I lubricate the pivot bolts to help reduce issues when it comes to removing them again in the future?
Old Jun 10, 2010 | 09:46 AM
DaJesterMan's Avatar
DaJesterMan
Yes there is a difference. I believe the earlier models had a 2 1/4 inch wide spring and the later model had a 2 1/2 inch wide spring. I just ordered a rear spring for my 1977 and I had to go out and measure which width the spring was. So I guess that was the transition year.
Old Jun 10, 2010 | 09:57 AM
Timsride's Avatar
Timsride
It looks to me You have the opposite of what I ran into.Your rear cover is probably for a 2 1/2 inch leaf and Your leaf is only 2 1/4 inch wide. I bought a 73 vert that the cover was broke so when I replaced it I bought a hd cover. It only fit 2 1/4 inch leaf, I realized this after I had installed it. So I had to get a 2 1/4 wide spring to fit.My spring also uses one two piece cup if that helps? I can't see yours to see what you mean by one cup.Good luck and it looks nice and clean under there. Timsride
Old Jun 10, 2010 | 10:13 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Yep, early C3's had larger spring to diff cover bolts, which means there's also a 1/4" inch difference between early C3 and later C3 spring widths. You can get a pair of spring spacers for a '78-'79 w/FE7 to take up the difference, so no need to change spring or cover to solve this.
Old Jun 10, 2010 | 10:24 AM
Fishndude's Avatar
Fishndude
I just noticed Corvette Central sells spring spacers under part # 583179 that are designed to go between the bolts and the leaf.. That sure would be alot cheaper than having to buy a whole new spring, especially since this one is already a new composite spring.
Here's a picture of the bushing cup I'm referring too. The kit only comes with one bushing cup
Old Jun 10, 2010 | 10:28 AM
Fishndude's Avatar
Fishndude
I think we posted at about the same time or I was still typing and didnt see your post before responding
Since I'm running a single mono leaf, I assume I will have to cut the height on the spacers? I guess that's still alot better than having to buy a new spring.
Old Jun 10, 2010 | 10:37 AM
wcsinx's Avatar
wcsinx
You could also just buy a new 2 1/4" cover which would be much cheaper than a new spring ($60ish IIRC). They're kind of a pain in the azz to swap out though. Or just use the spacers.
I believe that goes into the spring (from below). The inner lip should be a sloppy fit with the hole in the end of the spring. So looking from the bottom of the spring, the installation order would be
1 steel bushing cup
2 rubber bushing dome pointed down
3 washer
4 nut
5 cotter pin
TheSkunkWorks
Sorry, didn't account for this being a 'glass spring (haven't had my coffee yet). The one's I suggested might work fine with it, but if not seems logical there ought to be a set available for your particular combination. I'd check with where you got the spring.
Old Jun 10, 2010 | 10:55 AM
Fishndude's Avatar
Fishndude
I just found some other spacers that are "tubes" that slide over the bolts. Those would be alot easier to cut down if I cant find the correct height spacers due to the shorter height of the mono leaf.. Heck, I could probably just make my own..
1 steel bushing cup
3 washer
4 nut
5 cotter pin
Thank you, that's the info I needed.. Glad I ask because I was going to mount the cup in the trailing arm pocket
Old Jun 12, 2010 | 09:28 PM
Ozzyvet's Avatar
Ozzyvet
I had a chat with VBandP about spring widths a few months ago. Appparently all their springs are all the same width (2 1/4 inch). There are no twisting loads on the mount so the spacers aren't required and it should be fine with the gap. That was direct from their tech guy.
Old Jun 12, 2010 | 11:05 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Factory spacers used(front and rear) on 78/79s with the 2 1/4" wide gymkhana spring in the 2 1/2" housing....
Old Jun 13, 2010 | 01:40 AM
Fuelie74's Avatar
Fuelie74
Why not just swap on your original cover and be done with it?
Old Jun 13, 2010 | 06:59 AM
Fishndude's Avatar
Fishndude
Thank you for the picture
I just ordered the same spacers so that should do it..
Old Jun 13, 2010 | 08:13 PM
TheSkunkWorks
Perhaps you're not aware of what a chore that is vs. just installing spacers.
Old Jun 14, 2010 | 08:39 AM
Fishndude's Avatar
Fishndude
I agree, the last thing I want to do is drop that diff again..
To Rear Leaf Spring Help
