Popping in carb.
Old Jun 10, 2010 | 07:05 PM
Copacetic's Avatar
Copacetic
Default Popping in carb.
I am getting a pop under the choke plate. It happens when the choke opens and typically when I give it a little gas. It also typically kills the engine when it happens but not always. When it happens you can see a spark happen right and smoke comes out from the front part of the carb by the choke plate.
Old Jun 10, 2010 | 08:36 PM
thoyer's Avatar
thoyer
Check your timing and look for vacuum leaks
Tom
Old Jun 10, 2010 | 09:00 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
Or, worse yet a bent valve.
Old Jun 10, 2010 | 09:01 PM
Phil Zell's Avatar
Phil Zell
Could be a missing lobe on a camshaft.
Old Jun 10, 2010 | 11:01 PM
Korevette's Avatar
Korevette
Is it maybe running too lean ? Is it like a backfire?
Old Jun 11, 2010 | 11:55 AM
Copacetic's Avatar
Copacetic
Its got new heads new cam. Ill check for vacuum leaks and recheck the timing. I though it is running too lean but i dont really know how to fix that other then adjusting the choke.
Old Jun 11, 2010 | 03:54 PM
builder's Avatar
builder
Is the accelerator pump working properly?
Old Jun 12, 2010 | 01:46 AM
Korevette's Avatar
Korevette
What kind of carb are you running ?
I have had experience on Holley's and when getting a back fire, which by the way made me check the power valve, made me deceide the carb was to lean on the accelerator 'shot'. I increased the pump(s) cc's and then the shooter size until it stopped. I worked the accelerator ramps a bit and found that sweet spot.
I think Q-Jet and Carter or similar brands have options to change up the size of the accelerator shot to maybe stop that back fire if in fact that is the cause.
Dano,
Old Jun 12, 2010 | 11:48 AM
Copacetic's Avatar
Copacetic
Im running a 600cfm edelbrock. I increased the accelerator shot to max of the 3 settings it has. That seemed to help a bit but it still does it.
So Here is what i just did. I started it, it popped twice and died. I started it and kept it running for about 10 minutes and rechecked the timing. It was off by 8 degrees! This surprised me a little since i just did the timing a little bit ago. So I brung it up to idle at 700rpm and disconnected the vacuum hose. I set the timing to 8 degrees base timing. Then i re adjusted the idle mixture screws and found those were a little off and now it seemed to run quite a bit more sound. I killed the engine for a sec to take it out for a test drive. I started it and let it idle for 10 secs. then i gave it a little tap on the gas and POP! another effing pop! That was the only one of the whole test drive. It ran beautifully the whole drive. Very responsive and no popping. Why still that pop right when i gave it a little gas??
Old Jun 12, 2010 | 12:51 PM
Korevette's Avatar
Korevette
Maybe that carb is too small. I run a 750 DP on a 406 small block with old camel hump 461heads and .533 lift cam.
Hopefully someone can add to the thread to reveiw what you have. Sorry that is about all I can help you with.
Dano,
Old Jun 12, 2010 | 02:01 PM
Copacetic's Avatar
Copacetic
hmm maybe.. Im running it on the stock 350 block. With a .479 lift cam on some 70cc chamber edelbrock heads. maybe i should get a holley...
To Popping in carb.
